Farmall tractor and wagons planters - Router Forums
 12Likes
  • 6 Post By roofner
  • 6 Post By roofner
post #1 of 10 (permalink) Old 03-10-2018, 07:00 PM Thread Starter
roofner's Avatar
First Name: Gary
Default Farmall tractor and wagons planters
I have one of the wagons just about finished these are being built for a customer.
roofner is offline
post #2 of 10 (permalink) Old 03-10-2018, 07:34 PM
First Name: Ken
Cute...have you done the tractor yet?
kklowell is offline
post #3 of 10 (permalink) Old 03-10-2018, 07:47 PM Thread Starter
roofner's Avatar
First Name: Gary
In process about half finished. Most pieces are made but still need assembling. I have built several but customer wanted farmall look. This going to be dressed version.
Here is a previous build.
roofner is offline
post #4 of 10 (permalink) Old 03-10-2018, 08:38 PM
slick...
post #5 of 10 (permalink) Old 03-10-2018, 09:03 PM
First Name: Richard
Nice
Shop guy is offline
post #6 of 10 (permalink) Old 03-10-2018, 09:05 PM
Fun.
DesertRatTom is online now
post #7 of 10 (permalink) Old 03-10-2018, 10:09 PM
old55's Avatar
First Name: Ross
Nice.
Ross,
old55 is offline
post #8 of 10 (permalink) Old 04-01-2018, 07:12 PM
May need your help Gary. Just got home from Easter dinner at wife's folks. They want a big wishing well to replace the one that rotted away .... and the tractor (with Farmall colors) would be icing on the cake. I thought you did a thread with the measurements on the tractor earlier, Not sure if there was wishing well or not.
Will lumberyard pine work - painted and sparred?
HJ
Detroit Burbs
RoutervilleUSA on Etsy
honesttjohn is online now
post #9 of 10 (permalink) Old 04-01-2018, 08:24 PM
hawkeye10's Avatar
First Name: Don
Very nice. Will it haul hay?
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #10 of 10 (permalink) Old 04-03-2018, 12:27 AM Thread Starter
roofner's Avatar
First Name: Gary
Well John funny you should ask the wishing well uses the same size octagon rings as the tractor wheels just make 15 wheels the same size and the 16 is going have same inside dimension but the outside will be 2 inches wider for top cap.
I have 12 rings build and 6 painted and Saturday will paint the other 6. Then in a couple weeks finish the last 3 regular rings and top ring . Then paint those and screw the rings down in a staggered pattern. That will finish the well part haven't design the top part yet. The tractors are not finished need some paint work but not warm enough here to spray paint.
roofner is offline
