Another Clamp Rack - Router Forums
 19Likes
post #1 of 13 (permalink) Old 03-23-2018, 08:56 PM Thread Starter
DonkeyHody's Avatar
First Name: Andy
Default Another Clamp Rack
It all started when I found some clamps at half price. I only bought 4, but then found I had no space on the wall to hang them. Since I have quite a variety of clamps, no simple rack system was going to provide the flexibility I wanted. I did a little research online and combined several good ideas I found. French Cleats provide a sturdy method to hang things so you can still play with the spacing. Custom-built racks for each size and type of clamp allow them to hang fairly straight and best utilize wall space. The pictures tell the story . . .
We should be careful to get out of an experience only the wisdom that is in it and stop there lest we be like the cat that sits down on a hot stove lid. She will never sit down on a hot stove lid again and that is well but also she will never sit down on a cold one anymore. - Mark Twain
DonkeyHody is offline
post #2 of 13 (permalink) Old 03-23-2018, 09:32 PM
vchiarelli's Avatar
First Name: Vince
Andy - that's a nice setup - I've gotta do the same thing. Wondering how the support pieces are attached to the long arms at the top - can't tell from the pictures - are they sliding dovetails?
Cherryville Chuck likes this.
vchiarelli is offline
post #3 of 13 (permalink) Old 03-23-2018, 09:37 PM Thread Starter
DonkeyHody's Avatar
First Name: Andy
Check the close-up that's sitting on the table-saw. It's not a dovetail, just a 45 degree claw that fits on the 45 degree edge on the support board. Just lift it off if you want to.
post #4 of 13 (permalink) Old 03-23-2018, 09:43 PM
vchiarelli's Avatar
First Name: Vince
I think you're talking about the french cleat - I meant the top piece that's radiused at the front. How is it attached to the support triangle? See where I've place the red arrow.
post #5 of 13 (permalink) Old 03-24-2018, 12:22 AM
RainMan 2.0's Avatar
Great job Andy . I can’t get enough of clamp storage ideas . You certainly look well organized
I dont always insulate , but when I do .
Ok ,I never insulate
RainMan 2.0 is offline
post #6 of 13 (permalink) Old 03-24-2018, 01:42 AM
Great job Andy, I like your idea.
Herb Stoops is online now
post #7 of 13 (permalink) Old 03-24-2018, 07:03 AM Thread Starter
DonkeyHody's Avatar
First Name: Andy
Oh that. All the joints on that component are glued and screwed with pocket holes on the inside (where the clamp bar goes) surface.
vchiarelli likes this.
post #8 of 13 (permalink) Old 03-24-2018, 07:06 AM Thread Starter
DonkeyHody's Avatar
First Name: Andy
Originally Posted by RainMan 2.0 View Post
Great job Andy . I cant get enough of clamp storage ideas . You certainly look well organized
Lack of space is the Mother of organization. I'm not well-organized by nature. A lot of spare time, fueled by a little OCD (Obsessive Compulsive Disorder) certainly help.
post #9 of 13 (permalink) Old 03-24-2018, 07:14 AM
hawkeye10's Avatar
First Name: Don
Andy, you have some great ideas on clamp racks. I have clamps clamped to the horizontal framing on my garage door. I open it seldom. I also have very little wall space but if I did I would borrow your ideas on clamp racks.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #10 of 13 (permalink) Old 03-24-2018, 09:21 AM
Like the way you have the clamps stacked on each other rather than side to side - I don't know why more racks aren't made like this as it would seem that you can get more in less space. At least wall space - which is at a premium in most shops - there is a little more projection into the space. I have one of the Rockler Clamp Racks, a product I feel is a terrible design, and a redesign is working it's way to the top of my list. I saved the picture shown below, and plan on incorporating something like that into the Rockler rack - bolting a 2' x 4' piece of plywood to each side and attaching hangers for the various clamps to the sheets.
The frame of the rack is already at an angle so I can just drill the dowels in straight, the "tilt" of the plywood will keep the clamps from falling off and I figure that I can stack 6 - 8 F-clamps on each set of dowels. I'll probably lay the plywood across a pair of sawhorses and take some time moving the various clamps around to get the most efficient use of space. It would be better if I had the wall space but.......
tomp913 is offline
sanding blocks PhilBa Project Plans and How To 20 08-25-2015 07:26 PM
Rolling Clamp Rack todd628 Show N' Tell 11 04-25-2015 06:31 PM
Sheet Goods and Clamp Rack pdiesel75 Tools and Woodworking 6 09-30-2013 09:00 PM
Clamp Rack...Finally! CanuckGal Show N' Tell 55 12-11-2009 10:15 PM
Built in book shelf/ Shopnotes Clamp rack fasttruck860 Show N' Tell 14 09-25-2009 10:40 PM
