Desk build - Page 2 - Router Forums
 17Likes
post #11 of 23 (permalink) Old 03-30-2018, 07:53 AM
JOAT's Avatar
First Name: Theo
Can't view a single file.
Of course I'm not busy, I did it right the first time.
Call me a craftsman, artisan, or artistic, and I will accept that. Call me an artist and you will likely get a quite rude comment in return. I am not a @#$%ing artist.
JOAT is online now
post #12 of 23 (permalink) Old 03-30-2018, 09:41 AM Thread Starter
roofner's Avatar
First Name: Gary
Joat you need a sketch up viewer or sketch up program. I will put them as pdf files tonight.
Herb Stoops likes this.
roofner is online now
post #13 of 23 (permalink) Old 03-30-2018, 12:55 PM
JOAT's Avatar
First Name: Theo
I already have a sketch up program, but it sure doesn't work with that.
JOAT is online now
post #14 of 23 (permalink) Old 03-30-2018, 04:12 PM
Terry Q's Avatar
First Name: Terry
So is there a question or something you need help with?
Terry Q is offline
post #15 of 23 (permalink) Old 03-30-2018, 10:14 PM
JOAT's Avatar
First Name: Theo
Moving some wood and a chair into my shop is all I can come up with just now. When can I expect you?
JOAT is online now
post #16 of 23 (permalink) Old 03-31-2018, 12:51 AM
Thanks,Gary, that worked for me.
Herb Stoops is offline
post #17 of 23 (permalink) Old 04-03-2018, 12:36 AM Thread Starter
roofner's Avatar
First Name: Gary
Started build cut all the shelf frame pieces . Ready to start assembling frames. Then drill holes to attach frames to sides.
post #18 of 23 (permalink) Old 04-03-2018, 11:07 AM Thread Starter
roofner's Avatar
First Name: Gary
I assembled the shelf frames for the right side of desk . I am going to bolt the frames to the sides and middle supports. So middle frame support are not on yet because I'll need to drill holes first and put 5/8 inch particle board on top. The frames are 3/4 short because I'm going to put a suto face frame in front. Here is a picture of the frames.
post #19 of 23 (permalink) Old 04-05-2018, 12:12 AM Thread Starter
roofner's Avatar
First Name: Gary
I got all the holes drilled in the frames. Drilled the right side holes to connect shelf frames fit good. I did make one mistake forgot to account fot 1/2 mdf top shelf will be a 1/2 short. Instead of 6 inches it will be 5 1/2 no big deal. Trimmed the frames to accommodate the 3/4 inch face frame piece. I'm going to pick up 1/2 inch mdf for on top of shelf frames.
post #20 of 23 (permalink) Old 04-05-2018, 05:09 PM
First Name: Quenten
I would think the large of a knot would impact the strength of that corner.
Tonto1 is offline
Advice on router table - build or buy? newbie2wood Table-mounted Routing 45 11-06-2018 03:13 PM
New CNC build using 80/20 extruded aluminum Noob CNC Routing 46 11-22-2017 07:03 AM
Group Cyclone Dust Collector Build schnewj Project Plans and How To 99 08-23-2015 09:27 PM
To Buy or Build gaviaimmer Table-mounted Routing 12 12-12-2004 08:00 AM
