Tote Boxes - Router Forums
 24Likes
post #1 of 16 (permalink) Old 03-30-2018, 03:37 PM Thread Starter
CharleyL's Avatar
First Name: Charley
Default Tote Boxes
I make a lot of small decorative items in the later half of each year with my scroll saws.
I have used small cardboard boxes to hold the batches of small pieces of wood and the items in various stages of completion. These boxes never stacked very well and frequently fell over, dumping everything on the floor. So I tried small plastic tubs, and wasn't happy with them either. For the past two weeks, in between several other projects, I have been making some stackable tote bins to hold all of these small parts.
I made 12 of them, all from 10mm Baltic Birch. Each has a beveled 1 1/2" square piece of 10mm BB attached to the bottom as feet, and these double as a way to keep the stacked bins from sliding apart. Each has two coats of wipe on poly inside and out.
Now I'm thinking that I want to number all 4 sides to make finding the one that I want in the stack faster, but haven't decided how I want to do this yet. For a while, small Post-It notes will likely be attached to show what is in each.
The compound cut mailbox is one of my latest scroll saw projects. It is cut from one piece of wood, with only one glue joint. The flag shaft was cut from the same block of wood and then glued to the side of the mail box. This mailbox is 3 1/4" tall and made from poplar. I've made 4 of them so far and each time have tried different cutting methods. in an effort to improve both the quality and speed of cutting them out. So far, they are taking close to an hour to cut each one. The flag and the leaves on the vine were colored with marking pens, as another experiment. No finish has been applied yet either. I'm using a #1R Flying Dutchman blade for these.
Charley
Central North Carolina
CharleyL is offline
post #2 of 16 (permalink) Old 03-30-2018, 05:38 PM
JOAT's Avatar
First Name: Theo
Nifty boxes. Except you have to move them to get to the box you want, and that boils down to work. Years ago I made a puzzle book case, sorta. Sides, back, bottom, and they all slid together, no fastening. The sides were slightly slanted, so they would fit on the outside of the side of the section below. Best not to go more than four tall tho, or they will likely topple. And, cut a piece to fit between two stacks, and viola, you turn two into three, or three into five. I also made a piece that will fit on top making an open face stand, that one is at the end of my couch holding magazines. Some in the laundry room, my shop, and the rest line the wall of the hallway. Not near as nice looking as those tote boxes tho.
One of these days I'll try to dig out the masters, take photos, and post. Should be great for a college student.
Roy Drake likes this.
JOAT is online now
post #3 of 16 (permalink) Old 03-31-2018, 06:34 AM
First Name: Larry
Very nicely done Charley.
Knot working is offline
post #4 of 16 (permalink) Old 03-31-2018, 06:54 AM
Nice box joints. Are you using a commercial or a shop made jig?
DesertRatTom is online now
post #5 of 16 (permalink) Old 03-31-2018, 07:44 AM
First Name: Roy
I like this, Charley. I need to try it.
Roy Drake is offline
post #6 of 16 (permalink) Old 03-31-2018, 08:39 AM Thread Starter
CharleyL's Avatar
First Name: Charley
Tom,
They were made with an Incra I-Box jig on my Unisaw, using a Freud SBOX8 box joint blade set. I highly recommend this combination if you want an easy to set box joint jig and perfectly flat bottomed 1/4 & 3/8" wide kerfs. Several other saw blade manufacturers are now offering the same design blade set, but I only have experience with the Freud set. It's two blades with off set teeth. Put them together with the printed labels facing outward and they cut a 1/4" kerf. Put them together with the labels facing each other and they cut a 3/8" kerf. These box joints are 3/8"
I thought that you had bought an I-Box jig last year. Is my memory failing me?
Charley
DesertRatTom and Herb Stoops like this.
CharleyL is offline
post #7 of 16 (permalink) Old 03-31-2018, 09:15 AM Thread Starter
CharleyL's Avatar
First Name: Charley
Theo,
These are tote boxes, not a filing cabinet. I keep batches of parts in these so I can move them around the shop to perform the next machining step on each piece. I might work out of one and into a second one as I repeat the step on each piece. The boxes not in use will be stacked somewhere in the shop or may be stacked high enough next to the machine that I'm using to make the top one at the right height to be convenient for use at that machine. On toward Christmas when I ramp up production I will likely have all of the pieces for one pattern all in one tote box and pattern pieces for other patterns in other boxes. I'll likely attach small Post-It notes on the end of the boxes in use to make it easier to find the box containing the work that I want, but will then move it around the shop as I do the work to each piece. I was doing this with small cardboard boxes, but they didn't stack well and frequently got spilled, so rarely got stacked. These are designed so they stack together and shouldn't spill as easily.
Charley
Herb Stoops likes this.
CharleyL is offline
post #8 of 16 (permalink) Old 03-31-2018, 11:49 AM
TenGees's Avatar
First Name: Paul
Very nice boxes, Charley. Your little mailboxes are nice too. Don't recall seeing the seahorses though.
CharleyL likes this.
TenGees is offline
post #9 of 16 (permalink) Old 03-31-2018, 11:59 AM
hawkeye10's Avatar
First Name: Don
He makes some nice reindeer also. Charley makes a lot of nice stuff.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #10 of 16 (permalink) Old 03-31-2018, 10:00 PM
whimsofchaz's Avatar
First Name: Chuck
Nice stuff Charley. Wish I was that industrious.
whimsofchaz is offline
Wooden basket and boxes kywoodchopper Member Galleries 20 12-18-2017 11:07 PM
wooden boxes for kids kywoodchopper General Routing 15 10-30-2017 09:54 PM
Boxes from the Man Cave kywoodchopper General Routing 15 06-14-2016 06:28 AM
Boxes, Trivets and Stools xplorx4 Show N' Tell 5 10-26-2011 03:49 AM
Jack plane rear tote rwyoung Show N' Tell 3 11-16-2009 12:16 PM
