Shelved - Router Forums
 29Likes
post #1 of 13 (permalink) Old 05-20-2018, 04:24 AM Thread Starter
1fizgig's Avatar
First Name: Steve
Default Shelved
Howdy all, back for another instalment of "What will Steve make now?"
Today's project is a shelf unit to fit in the fridge space in the kitchen
When we moved here, our fridge was too big for the space, and since we're renting it's not like we can do a bit of remodelling.
So our fridge sits elsewhere, and we've had a small shelf and a few other things sitting in there since.
The story moves along to Mrs Fizgig asking for a box to sit under the microwave (currently located on our kitchen bench) to hide an accumulation of plugs and power boards that just look ugly.
Discussion ensues, and the ideas flow freely about what that might be like. Then I had an idea.
"What if I built a set of shelves to sit in the fridge space that the microwave could sit on?"
This met with approval, and so here we are dear readers, making a set of shelves.
The set I'm making measures 750mm wide x 1090mm high x ~450mm deep
I'm using 30mm thick pine for the sides and top for strength, and 18mm thick pine shelves. It's laminated panels, and it'll all get painted white.
1fizgig is offline
post #2 of 13 (permalink) Old 05-20-2018, 04:30 AM Thread Starter
1fizgig's Avatar
First Name: Steve
I've cut out all the pieces with the circular saw. Not as confident as I would be with the mitre saw, but the lengths mean that's not an option. Another tick for getting a table saw in the future.
Still, it wasn't too bad, a little trimming required but I'm pretty happy with the results.
Now, you'd be wondering, what do you want to use a router for on this?
Well, I'll tell you. I decided that in order to mount the shelves in the unit in a more secure way, I'd rout a dado into each side panel to slot the shelf into and screw it in from the side.
That way it's well supported on the ends of the shelf without relying solely on screws (or glue).
I didn't think to take photos early in the piece, so we pick up when I routed out the first dado.
I clamped both side panels flat togetherto measure and cut evenly across both pieces, all the better to make sure the dadoes were at the same height on both sides. Don't want wonky shelves now, do we?
1fizgig is offline
post #3 of 13 (permalink) Old 05-20-2018, 04:32 AM Thread Starter
1fizgig's Avatar
First Name: Steve
Here we are with the second dado cut and tools out of the way.
I had to clean the dadoes up a little with sandpaper, the top edges were a little "furry", but that's nothing.
I did have a little chatter briefly in the second dado (as evidenced by the slight scorch mark), because I seemed to suddenly have an issue moving the router across the wood. I discovered one of the screws holding the base on had undone itself a bit and was dragging across the wood.
Lesson learned, check all screws when you know you've recently changed bases.
MT Stringer, TenGees and old55 like this.
1fizgig is offline
post #4 of 13 (permalink) Old 05-20-2018, 04:40 AM Thread Starter
1fizgig's Avatar
First Name: Steve
And here we are getting into the assembly. The sides are joined to the top with pocket screws,
I had some issues with my Kreg gear. The square drive bit for some reason seemed to get itself locked into the screw head and ended up stripping some of the holes completely out. I was _NOT_ happy. I've contacted Kreg to voice my disappointment, as this tool has not lived up to expectations in the short amount of use it's actually seen.
I think I'll have to grind down the tip to prevent it sticking, whilst not going so far that it's too sloppy and strips the heads.
My shelves are in need of a little adjustment to make sure they sit flush, which I'll do soon, then painting can begin.
The dadoes work great on the shelves though, so I'm really happy to have decided to try this. The large bit I used to cut the dadoes was 19mm, gives just enough play to mean the shelves slide in with very little slop.
Not sure if the structure is sturdy enough without cross or corner bracing at this stage until I've screwed the shelves in. I am satisfied it'll handle the weight ok, but I may add some corner brackets just for peace of mind.
1fizgig is offline
post #5 of 13 (permalink) Old 05-20-2018, 05:18 AM
for strength put a back on it or at least gusset ALL of the inside corners...
post #6 of 13 (permalink) Old 05-20-2018, 11:11 AM
MT Stringer's Avatar
+1 What Stick said. A back will add strength and prevent the unit from racking.
Enjoying watching you build your project.
JFPNCM and Herb Stoops like this.
MT Stringer is online now
post #7 of 13 (permalink) Old 05-20-2018, 12:30 PM
Shelving earns a guy lots of husband points Steve. Nice so far. Going to use a face frame or edging?
post #8 of 13 (permalink) Old 05-20-2018, 04:34 PM
Good looking material,you are useing, and you are doing a good job too.
Herb Stoops is online now
post #9 of 13 (permalink) Old 05-21-2018, 12:19 AM
old55's Avatar
First Name: Ross
Nice job Steve.
Ross,
old55 is offline
post #10 of 13 (permalink) Old 05-22-2018, 07:29 AM Thread Starter
1fizgig's Avatar
First Name: Steve
Default Thanks everyone for the nice comments
And Tom, Mrs Fizgig laughed when I passed on about your comment (secretly though, you're right).
I hadn't considered a face frame or edging to be honest. It's going in the kitchen, could possibly use a little something..... I'll ponder.
Update on the Kreg situation: I got contacted by Kreg - they're replacing my jig, should arrive some time next week. Now that's customer service. I was impressed with the speed they responded and in their offering me another one to try and redeem my expectations.
I look forward to trying it out with some trepidation, but am hoping for the best.
Thank you all for chiming in and your encouragement. This is why I love this forum.
Screwed the shelves in today after adjusting the fit - happy with the result, does help on the stability, but I am seriously considering brackets. I have small metal ones I can use easily.
1fizgig is offline
