Tambour Clock Build - Router Forums
 34Likes
post #1 of 15 (permalink) Old 06-07-2018, 02:26 PM Thread Starter
bcfunburst's Avatar
First Name: Reg
Default Tambour Clock Build
This is a project I had in mind for a long time. It took me a long time to figure out how I was going to do the process. Keep in mind I am no perfectionist! We wanted a clock that we can see while watching TV, so we don't have to check the TV guide to know what time we have left.
I was given the Black Walnut Mill Ends used for this clock. The clock works came from Lee Valley Tools and the rest came from my own imagination. I will try to relate the process without getting too windy; attaching related photos.
I sized the blanks with a thickness planer first and filled one knothole in case the piece was included. Next the pieces had to be cut and joined, using my biscuit joiner. After drying time for the glue, I laid out the clock face and made a pattern to decorate the body of the clock. That part was the most work of the entire project. I had to rework the pattern for the carvings three times, to get something I could enjoy viewing regularly. Next job was to cut the shape of the clock body with the band saw, followed by some sanding to clean up the shape of the body.
I used a pin arm attachment to carve the pattern around the clock face. Carving out excess waste with a 1/4" spiral bit took two passes to get the depth required. Edges were rounded off with a plunge 1/4" beading bit/ 1/2" shank; followed by a lot of fiddly finger sanding. Cutting out the space for the clock motor in the back was accomplished with a 1/4" spiral bit first, for a thin cover. The deeper cavity for the motor was cut out with a 1/2" forstner bit on the drill press.
The finish is Teak Oil; 3 coats; more sanding between coats.
Total dimensions: 23" long by 11" high and 2" thick. The feet are 3" wide with felt pads to avoid any scratches on the mantle. Assembling the clock face and hands was a chore in itself for an old guy that is half blind.
More photos available if needed.
"Even bad decisions make good stories"
<bcfunburst>
bcfunburst is offline
post #2 of 15 (permalink) Old 06-07-2018, 02:32 PM Thread Starter
bcfunburst's Avatar
First Name: Reg
Default Tambour Clock Photos
More Photos
<bcfunburst>
post #3 of 15 (permalink) Old 06-07-2018, 03:30 PM
Fantastic job, you went into quite a bit of detail work in that project. It sure came out nice,and the finish is really a deep chocolate color, makingthe dial stand out perfectly. Good Job.
bcfunburst likes this.
Herb Stoops is offline
post #4 of 15 (permalink) Old 06-08-2018, 06:03 AM
Yup - what Herb said!!
HJ
Detroit Burbs
RoutervilleUSA on Etsy
honesttjohn is online now
post #5 of 15 (permalink) Old 06-08-2018, 07:09 AM
hawkeye10's Avatar
First Name: Don
Yep! I could not have said it better than Herb.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #6 of 15 (permalink) Old 06-08-2018, 07:13 AM
difalkner's Avatar
First Name: David
Very nice project and a good looking clock, Reg!
David
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is online now
post #7 of 15 (permalink) Old 06-08-2018, 08:34 AM
MEBCWD's Avatar
Reg that is really a nice clock. That is also a good example of pin routing. Nice job. Thanks for sharing.
bcfunburst and TenGees like this.
MEBCWD is online now
post #8 of 15 (permalink) Old 06-08-2018, 09:11 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
I very nice clock Reg. and we need more photo-shoots like you have presented.
Harry
harrysin is offline
post #9 of 15 (permalink) Old 06-08-2018, 09:28 AM
First Name: Gary
Reg, What a beautiful piece of art with function! I was wondering how when using a pin router, do you plunge in the middle of a board to get started carving something like this? I understand the concept of how it is guided by the pin, but wondered how you get started safely? Also does teak oil have varnish or something besides oil?
gmercer_48083 is online now
post #10 of 15 (permalink) Old 06-08-2018, 10:52 AM
Really nice job on that clock. Deep, rich finish is beautiful, gives the impression of an antique.
I'm having problems offloading pictures from my phone, so I'm going to start keeping a camera in the shop.
Advice on router table - build or buy? newbie2wood Table-mounted Routing 45 11-06-2018 03:13 PM
New CNC build using 80/20 extruded aluminum Noob CNC Routing 46 11-22-2017 07:03 AM
Curly Maple and Walnut cross - Build thread difalkner Show N' Tell 51 04-23-2017 02:45 PM
Router Table Build whimsofchaz Table-mounted Routing 17 10-20-2016 04:07 PM
To Buy or Build gaviaimmer Table-mounted Routing 12 12-12-2004 08:00 AM
