Part II in IPAD/TABLET Build - Router Forums
 23Likes
  • 13 Post By Herb Stoops
  • 4 Post By Herb Stoops
  • 1 Post By old55
  • 1 Post By MEBCWD
  • 1 Post By Stick486
  • 1 Post By TenGees
  • 1 Post By Herb Stoops
post #1 of 10 (permalink) Old 06-14-2018, 06:28 PM Thread Starter
Default Part II in IPAD/TABLET Build
Here are the pictures of the smaller IPAD?TABLET build.
I apologize for the blurry picture of the toothpick dowels I used to hold the back support aligned while the glue is drying.
Herb Stoops is online now
post #2 of 10 (permalink) Old 06-14-2018, 07:50 PM Thread Starter
Before Stick jumps all over me for the bar clamps from HF, these are US made bar clamps.
post #3 of 10 (permalink) Old 06-14-2018, 08:43 PM
old55's Avatar
First Name: Ross
Looking good Herb.
Herb Stoops likes this.
Ross,
old55 is offline
post #4 of 10 (permalink) Old 06-15-2018, 09:41 AM
MEBCWD's Avatar
Herb I have a mini router table just like the one you have in the 5th picture!
MEBCWD is offline
post #5 of 10 (permalink) Old 06-15-2018, 11:45 AM
wow Herb...
now look how great they turned out w/o any HF...
post #6 of 10 (permalink) Old 06-15-2018, 12:13 PM
TenGees's Avatar
First Name: Paul
Looking good, Herb. I guess you had to hide your HF clamps for the pictures.
TenGees is offline
post #7 of 10 (permalink) Old 06-15-2018, 12:25 PM Thread Starter
Sure handy little devils,aren't they.
post #8 of 10 (permalink) Old 06-15-2018, 12:27 PM Thread Starter
SHHHHHHHH...........not too loud. Sure miss the free flashlights and stuff tho.
TenGees likes this.
post #9 of 10 (permalink) Old 07-08-2018, 08:46 AM
papasombre's Avatar
Country: Venezuela
First Name: Alexis
May you give more details about the way you attached the trimmer to the vise in picture 5?
We, woodworkers are everywhere!!!
papasombre is offline
post #10 of 10 (permalink) Old 07-08-2018, 10:24 AM Thread Starter
To answer your question, I set the PC router upside down on the work bench and then clamp the base in the vice. The PC router has a sort of square shaped base that just fits into the vice.
A person could make a clamping jig that fits around the router motor and clamp it in the vice, or build a small box that a trim router could be mounted inside and turned upside down with the bit sticking through the bottom.
papasombre likes this.
Advice on router table - build or buy? newbie2wood Table-mounted Routing 45 11-06-2018 03:13 PM
New CNC build using 80/20 extruded aluminum Noob CNC Routing 46 11-22-2017 07:03 AM
Curly Maple and Walnut cross - Build thread difalkner Show N' Tell 51 04-23-2017 02:45 PM
Router Table Build whimsofchaz Table-mounted Routing 17 10-20-2016 04:07 PM
To Buy or Build gaviaimmer Table-mounted Routing 12 12-12-2004 08:00 AM
