Planing slabs - Router Forums
 16Likes
  • 12 Post By botanical
  • 1 Post By DesertRatTom
  • 2 Post By harrysin
  • 1 Post By Cherryville Chuck
post #1 of 9 (permalink) Old 07-14-2018, 01:05 PM Thread Starter
First Name: Bo
Send a message via AIM to botanical
Default Planing slabs
Hi there,
I just joined the forum recently as I'm new to routing. The reason was that I have come into possession of some Elm slabs and want to make some tables. I got a lot of really good advice on the 'introduce yourself' page about ski's and stuff and which bits might work. I'm in the UK and large diameter bottom planing bits appear to be hard to find ( Infinity were out of stock ). Someone recommended Freud bits but even then I had to get it sent from the US. There's an opportunity here somewhere to corner the market.
Anyway I want to thank everyone for the sage advice and the reading materials. These slabs are quite large so I was a little daunted with the idea of starting. However after many encouraging posts I decided to have a go, if only on a scaled down version so I made a 'ski' box and a sled about 2'x4' and played around with some Cherry offcuts. I am very happy with the experience and also the results and now feel much better about starting my big project. So thanks to all of you who imparted advice, there are too many to mention which says a lot about the community here. Thankyou.
PS sorry the picture is odd, haven't sorted how to rotate images yet.
botanical is offline
post #2 of 9 (permalink) Old 07-14-2018, 03:09 PM
Gene Howe's Avatar
First Name: Gene
Nice work, Bo. What bit did you end up using? Don't know if you can get a bowl bit but, they work well for flattening.
Gene Howe
Snowflake, AZ
Gene Howe is offline
post #3 of 9 (permalink) Old 07-14-2018, 07:55 PM
I've never had a problem I couldn't handle, IF I thought it through thorouthly before starting on it. I guess there just aren't enough woodworkers in the UK to justify stocking a number of stores. Even in the US, there are hundreds of miles between woodworking stores, so, many of us wind up ordering online.
Gene Howe likes this.
post #4 of 9 (permalink) Old 07-15-2018, 07:02 AM
sreilly's Avatar
First Name: Steve
It seems the older I get the more it takes to do something "new". I tend to overthink it sometimes and when I finally get started it turns out the worry was really not needed. Not rushing in makes sense as long as it doesn't paralyse you from doing the project. The worst that could happen is you make a mistake and learn something new. As long as it's carefully done you'll have either accomplished the project or learned a lesson that should build up your skills. My closest woodworking store is 90 minutes away but Amazon is but a click. Probably by design for my own sake.
Looks like you're on your way. Good luck.
sreilly is offline
post #5 of 9 (permalink) Old 07-15-2018, 09:33 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
I've had excellent service from bits like this from China.
https://www.ebay.co.uk/itm/1-2-Shank...EAAOSwIBNbQDhL
swarfmaker and TenGees like this.
Harry
harrysin is offline
post #6 of 9 (permalink) Old 07-15-2018, 10:09 AM
First Name: Gary
Bo, To fix orientation of your pictures, upload your photo to your pc,s photo editor, rotate it to orient (even when it looks right), save...then upload it to routerforums. For unknown reasons photos from your cell phones seem to only display correctly on the phone.
gmercer_48083 is offline
post #7 of 9 (permalink) Old 07-16-2018, 09:30 AM
harrysin's Avatar
First Name: Harry
I use "paint.net" which is a FREE program and I find it better that "paint" which is part of windows. Here you can turn, adjust brightness, colour, contrast etc. and add text.
The more you use it the easier it gets.
https://www.getpaint.net/
Harry
harrysin is offline
post #8 of 9 (permalink) Old 07-16-2018, 10:33 AM
First Name: Bob
For a woodworking forum, I certainly learn more about computer technology. Thanks, Harry, for sharing the link to paint.net I will have to check it out.
Web Shepherd is offline
post #9 of 9 (permalink) Old 07-16-2018, 11:41 AM
I use Irfanview for some of the same reasons but it also gives me an opportunity to annotate the photos as Harry did in his.
DaninVan likes this.
Trimming & Stacking Slabs tomp913 Tools and Woodworking 9 11-01-2015 09:28 AM
Push or Pull Hand Planing Herb Stoops Lobby 9 01-11-2015 02:47 PM
Planing with a Router Gilbear Portable Routing 51 05-17-2012 04:40 PM
