Layout Tool Storage - Router Forums
 12Likes
  • 12 Post By Dejure
post #1 of 5 (permalink) Old 07-14-2018, 10:59 PM Thread Starter
Dejure's Avatar
First Name: Kelly
Default Layout Tool Storage
Im all over the board on what I do in my shop, so I have a significant and, seemingly, ever growing collection of layout tools. I had dedicated a 4x8 section of wall space to storing and displaying them so I could spot what I needed for a given project with just a glance. It wasnt enough and my many circle templates, compasses, triangles, parallel guides and many other items sat in boxes I had to go through, as need arose.
I solved the space problem by building a storage system similar to the displays you see used for posters. However, my panels are 2 wide by 4 tall and about 1-1/4 thick. They mount in two pieces of 4 long, pre-drilled angle iron mounted to the wall.
The completed project takes up 16 square feet of the 32 square feet I set aside for layout tools and gives me 64 square feet of play area, plus a little between panels.
I have three panels mounted and have room to add one more, which is scheduled to be completed sometime in this decade. Meanwhile, I can also install things on the wall, between the panels.
I built the panels using junk 3/8 plywood, which I used to sandwich 1/2 square stock (spacers) I cut from 2xs. The spacers ran around the outer edges, and two were spaced evenly through between the ends.
Once the panels were built, because I forgot to add reinforcement at the corners when assembling them, I added five inch pieces of aluminum angle stock I had on hand to the completed panels. These mounted on the exterior of the panels, at the top and bottom, where the panel would sit in the angle iron on the wall. To avoid having to add the aluminum or other reinforcement, I could have added spacers an inch or so wide and the same thickness as the perimeter spacer stock to the corners.
Once the angle aluminum was in place, I drilled holes for 3/8 dowels on the top and bottom. The holes were about 5/16 back from the edge (to allow the panels to pivot without hitting the wall or angle iron). The bottom dowel is glued in place. The top one can be removed, to allow me to install and remove the panels independently.
Name:	Tool Racks-1.jpg
Name:	Tool Racks-2.jpg
Name:	Tool Racks-3.jpg
The reason I have what you want is, I never lent it out before.
Scraps are a myth.
Dejure is offline
post #2 of 5 (permalink) Old 07-15-2018, 07:12 AM
Very nice, that certainly lets you arrange all the various tools to make them easy to find. Sure wish that I had the available wall space.
tomp913 is offline
post #3 of 5 (permalink) Old 07-15-2018, 09:52 AM
First Name: Gary
Kelly, This project is a Great Example about stretching your wall space. Thanks for showing.
gmercer_48083 is offline
post #4 of 5 (permalink) Old 07-15-2018, 11:15 AM
This is an interesting take on storage, kind of a 3D approach. I found that laying all my unique items out on a wall helps me remember what I actually have, otherwise I'd forget and buy duplicates! Hard not to buy something on those rare occasions I get to a woodworking store.
post #5 of 5 (permalink) Old 07-15-2018, 01:04 PM Thread Starter
Dejure's Avatar
First Name: Kelly
I suspect more than a few of us have a duplicate too. Of course, most of the duplicates are probably shiny.
Scraps are a myth.
Dejure is offline
Tool Review Guidelines ~ READ BEFORE POSTING Mark Tool Reviews 5 01-18-2020 09:11 AM
Results do not match 3d preview edison auto CNC Routing 46 04-02-2016 05:58 AM
Multi tool useage mgmine Tools and Woodworking 35 02-14-2016 02:20 PM
Chinese W1325ATC CNC - tool positioning semenov419 CNC Routing 2 01-29-2016 08:48 PM
Feeds & Speeds LMT Onsrud (Onsrud) Router Bits - Types and Usage 0 02-12-2012 02:51 PM
