Cake Ball Display - Router Forums
 85Likes
post #1 of 42 (permalink) Old 09-01-2018, 05:04 AM Thread Starter
MEBCWD's Avatar
Default Cake Ball Display
Our oldest daughter makes cake balls and she had a woman contact her about making cake balls for her wedding. She also wanted them displayed on a three-tier stand so guess who was ask to make the display.
I used birch plywood for the tops and sides of the tiers and select pine for the trim to help keep the cost of materials down. All the hardware is stainless steel so no rust and easy to clean. I did miss taking a few pictures near the end of the project. I guess I was worried about getting it finished and did not think about taking pictures.
I used pocket holes to assemble the tops and sides of the tiers. I used the CNC to drill all the holes in the tops to hold the cake ball sticks. I cut the trim profile on both sides of the trim blanks then cut the trim from the blanks. I made the risers from select pine boards glued up and trimmed square. The pictures do show all of this but there were other parts made and I did not get pictures of them.
I made a support box that goes under the bottom tier that the all thread rod that holds everything together goes through and washer and wingnut clamps against. There is also a block bonded in the top tier that is glued up with a wingnut and washers inside to receive the top of the all thread rod. That block was machined on the CNC so the wingnut and washers could be inserted.
To drill the holes in the 10 1/2" risers I had to use my Shopsmith knockoff and it was buried in the corner of the shop and had not been used for about 8 years.
MEBCWD is online now
post #2 of 42 (permalink) Old 09-01-2018, 05:09 AM Thread Starter
MEBCWD's Avatar
Of course when it was delivered she was making cake balls and she forced me to eat some of the mistakes.
post #3 of 42 (permalink) Old 09-01-2018, 06:30 AM
First Name: Al
In all probability, I'm sure, she r_e_a_l_l_y had to twist your arm.......lol
HoweA is online now
post #4 of 42 (permalink) Old 09-01-2018, 06:56 AM
sreilly's Avatar
First Name: Steve
Never heard of cake balls but hey, some mistakes are good! Looks like the project turned out great.
sreilly is online now
post #5 of 42 (permalink) Old 09-01-2018, 08:23 AM
First Name: Fred
I've never heard of cake balls but can imagine they are just as yummy as a standard-shaped cake. My question concerns the purpose of all the drilled holes on the base of each platform. What's up with those?
Danman1957 likes this.
spike1 is offline
post #6 of 42 (permalink) Old 09-01-2018, 08:42 AM
I believe the decorated cake balls are put on sticks and then stood up in the holes.
Mike -- yur 1 of dem injuneres now 2.
Above us common folk!! lol not
MT Stringer likes this.
HJ
Detroit Burbs
RoutervilleUSA on Etsy
honesttjohn is online now
post #7 of 42 (permalink) Old 09-01-2018, 09:44 AM
TenGees's Avatar
First Name: Paul
Looks good Mike, you deserve at least the bloopers for that!
TenGees is offline
post #8 of 42 (permalink) Old 09-01-2018, 09:52 AM Thread Starter
MEBCWD's Avatar
I guess these would be called cake pops because they will be on small round sticks like lollipops. The holes are for the sticks to hold them. She normally just makes the cake balls, dips them in melted chocolate and sets them aside for the coating to set up.
The ones she FORCED me to eat had been dipped in the wrong flavor of chocolate, a good mistake.
These are for another order she had this weekend.
post #9 of 42 (permalink) Old 09-01-2018, 11:04 AM
First Name: Richard
Nice project, Mike. I’m all for eating culinary mistakes.
Herb Stoops likes this.
Shop guy is offline
post #10 of 42 (permalink) Old 09-01-2018, 12:07 PM
Of course, we have to do what the ladies in our lives command.
MEBCWD likes this.
Forum Suggestion Thread Mark Site Help and Suggestions 131 02-08-2015 09:33 AM
Segmented Circle Arrowhead Display Stand routergieck Show N' Tell 16 01-19-2014 07:04 AM
Room divider finished jigger Jiggers Gallery 17 09-26-2011 11:05 PM
Plans for wedding cake display case? glassguy1456 Tools and Woodworking 2 12-16-2004 12:23 PM
