I have seen the light (2) - Router Forums
 14Likes
post #1 of 12 (permalink) Old 09-18-2018, 10:19 AM Thread Starter
First Name: Colin
Default I have seen the light (2)
Hi there fraternity.
Just a short extension to my previous post where I attempted to light up my life with some led spots over some of my machines.
This time it was the grinders turn. I use it quite a lot and it’s a good servant so decided to give it a treat. It’s a 3phase 415volt machine with 12-inch wheels, but suffers from a lack of overhead lighting.
I think the photos show the procedures. There was a small taping on the top of the casing that originally supported a small shelf, so bored it out and tapped it to 1/2-inch BSP. this allowed me to screw in a stand pipe directly into the casing. The reason being it would give me the earth route I required. The stand pipe is from a bottom entry we cistern used to accommodate a FOV. Sometimes referred to incorrectly as a ballcock. I also installed the lid of an electrical isolator box to act as a shelf.
I didn’t see the point of fitting two lights so soldered a brass screw into a piece of 15mm copper pipe that would allow the light to swivel either way.
Protected the cable through the hole in the pipe with heat shrink.
Next problem was an electrical supply. Again, same problem as last time, this machine had no neutral, only phase, phase, phase and earth. I wanted the light to come on as the grinder was switched on so. live connected to one of the phases on the switch wire to motor, bringing it on with the motor, and ran in new neutral to the machine.
I know sometimes some people use an earth point if no neutral available, but apart from being against the IEE regs it can cause problems if you have an RCD on your consumer unit (residual current device) which detects leak to earth it can inadvertently trip the device. So, based on that I ran a neutral.
Cost £8.
Nice to look at, No.
Works Yes.
Colin
Scotland
Coleve is offline
post #2 of 12 (permalink) Old 09-18-2018, 10:39 AM
Gaffboat's Avatar
First Name: Oliver
Nicely done, Colin. Once the copper tubing develops a little patina, the light is going to look like it was always part of the machine.
TenGees likes this.
Gaffboat is offline
post #3 of 12 (permalink) Old 09-18-2018, 03:04 PM
TenGees's Avatar
First Name: Paul
Heckuva grinder... improved. Nice job, Colin.
TenGees is offline
post #4 of 12 (permalink) Old 09-18-2018, 10:34 PM
LED spots over a tool really make it easier to work with it. I have lights on both my large and smaller band saws. Pix attached. Both lights started as $12 goose neck lights one from a store, the other, longer from a thrift shop. Found a 50 watt equivilent LED spot light. Bracket on one was salvaged from my old drill press, the other is set into an electrical box. Put a switch into the larger saw's box. Simple to do, but classy results.
Name:	light on Rikon 12.jpg
Name:	bandsaw light.jpg
TenGees and jj777746 like this.
post #5 of 12 (permalink) Old 09-19-2018, 07:06 AM
Knothead47's Avatar
Nice project! Well thought out and designed.
It is interesting that preliminary studies are indicating some vision problems with LED lighting. Should be "enlightening" as to the final analysis.
John T.
Knothead47 is offline
post #6 of 12 (permalink) Old 09-19-2018, 10:27 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
Great ingenuity and workmanship.
Harry
harrysin is offline
post #7 of 12 (permalink) Old 09-19-2018, 11:15 AM
Contributor of the Month
Bushwhacker's Avatar
First Name: David
What are your thoughts on this Tom?
When the enemy is in range, so are you.
Bushwhacker is offline
post #8 of 12 (permalink) Old 09-19-2018, 01:47 PM
Some people are highly sensitive to the blue spectrum and don't react well. All LEDs start with a lot of blue light, but they coat the emitter to block it. Cheaper bulbs eventually burn throught the coating and get far bluer over time. My research showed that CREE and Philips are considered the premium brands at this time, with coatings that don't deteriorate. I have noticed no blue shift so far in my home and shops.
All my lighting is LED now, all about 2800 to 3000 K, or "warm white".
Blue light has been found to interfere with sleep, for example, looking at an LED backlight computer or TV screen. The brain treats blue light as a "wake up, it's daytime, get going!" signal. Lots of research on that. I think that might be part of the sensitivity issue. In cheap bulbs, the power supply may cause a little flicker, which the brain treats as a danger signal when it occurs in the peripheral areas of the retina--this triggers a chemical stress response that over time is destructive to the involved tissues.
The picture shows the spectrum of both 3,000 and 5-6 K lights. You can clearly see the difference. For film, video or photographic purposes, the 5 to 6 K lights are preferred since they match daylight's spectrum. I personally find the blue-white LEDs unpleasant.
Name:	LED 2800K spectrum.png
post #9 of 12 (permalink) Old 09-19-2018, 02:04 PM
MEBCWD's Avatar
Colin,
Great solution to get plenty of light on that grinder.
MEBCWD is offline
post #10 of 12 (permalink) Old 09-19-2018, 02:31 PM
I recently got a small grinder and haven't set it up yet. Don't need it much, and a little concerned about all those sparks flying around. Any suggestions?
I have seen the light Coleve Show N' Tell 9 08-15-2018 05:25 PM
Best working light ever? re-purposed dental light JCJCJC Lobby 11 01-03-2016 10:03 AM
Aging Cherry Using Artificial Light? BigJimAK Tools and Woodworking 13 09-06-2010 12:57 PM
Help with a LDR Light Dark Relay. Any electricians here? unlimitedwoodworker Lobby 5 09-03-2008 11:50 PM
