Descktop Pencil Holder - Router Forums
 68Likes
post #1 of 21 (permalink) Old 12-22-2018, 04:41 PM Thread Starter
Default Descktop Pencil Holder
The story behind this little "What is it", is that I had this 1/2 log piece that came with the lumber stash,pic1. I didn't know what kind of wood it was so I cut a about 6" off the end to clean up and see what I had. It turned out to be Maple. I didn't want to just throw away the piece so thought I would make a band saw box out of it.
So I cut the bottom off, cut out the center, glued up the sides and reattached the bottom. The cut on the bottom looked ugly so I made a molding and then made some feet for it and called it a desktop pencil holder.
The finish is 2 coats of spray shellac, and 6 coats of water based poly thinned 50/50 with water. I did stained the base/feet ,because it looked better next to the bark.
Not my finest work, but I saved it from the trash bin.
kp91, jw2170, Marco and 23 others like this.
Herb Stoops is offline
post #2 of 21 (permalink) Old 12-22-2018, 07:01 PM
RainMan 2.0's Avatar
That’s quite unique Herb , nice job. I’m wondering the left over piece could be sliced and used as dividers ?
Ok ,I never insulate
RainMan 2.0 is online now
post #3 of 21 (permalink) Old 12-22-2018, 07:18 PM Thread Starter
Originally Posted by RainMan 2.0 View Post
Thatís quite unique Herb , nice job. Iím wondering the left over piece could be sliced and used as dividers ?
Rick,you might just have something there. Good idea, I had not thought of that. I will check that out.
post #4 of 21 (permalink) Old 12-22-2018, 08:25 PM
Itís quite wide . My concern was they would fall over . Thought a couple of dividers would do the trick
post #5 of 21 (permalink) Old 12-22-2018, 08:40 PM
1st rate Herb..
Herb Stoops and jj777746 like this.
post #6 of 21 (permalink) Old 12-22-2018, 08:56 PM
jj777746's Avatar
Not your finest work is still better than a lot of my finest work,Herb. And imo would look good on anyone's desk. James jj777746
papasombre and Herb Stoops like this.
You can't drive a bridge spike with a tack hammer(so I'm told)
jj777746 is offline
post #7 of 21 (permalink) Old 12-22-2018, 10:00 PM
old55's Avatar
First Name: Ross
Nice work Herb.
Herb Stoops likes this.
Ross,
ĎMembers are requested to add a first name in their profile as we are a very friendly bunch here'.
old55 is offline
post #8 of 21 (permalink) Old 12-23-2018, 07:55 AM
Danman1957's Avatar
Herb,
I like the rustic look with the bark still on, I think you might have started a new trend for pencil holders
Dan
Don't fear your tools, pay attention and respect the tools and avoid injury.
Danman1957 is offline
post #9 of 21 (permalink) Old 12-23-2018, 09:58 AM
First Name: Ellery
Very nice work Herb!
Thank you for posting the sequence of your creation. I think dividers would be a very nice touch.
Great idea Rick.
Arcola60 is online now
post #10 of 21 (permalink) Old 12-23-2018, 10:02 AM
TenGees's Avatar
First Name: Paul
I like it, Herb. I have some firewood that I might have to try that with. Did you partially sand the bark?
TenGees is online now
Need help: Routing a pencil holder on desk top gregrlevy General Routing 4 10-29-2015 10:02 AM
pen adapter --sharpie or HB regular pencil woodman12 CNC Routing 0 06-01-2015 09:39 PM
Milling a bit and wrench holder houdini28 CNC Routing 2 04-03-2015 10:15 PM
keep loosing my pencil, driving me nuts! kibodwin Lobby 26 02-07-2015 12:28 AM
How to Make a Pencil Box learnexperience Tools and Woodworking 2 08-10-2011 12:45 AM
