something simple - Page 2 - Router Forums
 51Likes
post #11 of 21 (permalink) Old 01-17-2019, 07:45 AM
sreilly's Avatar
First Name: Steve
So you end up making multiple units, get tons of cookies, and end up having to start a gym membership. Wheer's the "fair" in that? Hope they are all great cookies........really nicely done.
JFPNCM and artman60 like this.
sreilly is offline
post #12 of 21 (permalink) Old 01-17-2019, 07:53 AM
First Name: mary
I would like something like that with a edge on the bottom to hold my painting or needle felting work and keep it up closer to my face. Eyes aren't what they use to be
MEBCWD, Herb Stoops and artman60 like this.
marecat3 is offline
post #13 of 21 (permalink) Old 01-17-2019, 09:56 AM
First Name: Jose
Default Question for "Something Simple"
Great work products that have obviously satisfied your clients. Watch out for the cookies, though. Once on the lips, always on the mid-rift! Seriously though, there are many of us that have developed difficulty in the use of our hands. For us, door levers are easier to turn than door knobs. Similarly, in designing jigs I always use levers instead of knobs, for the same reason. But, overall, your design is great.
What is the gadget in the last image? It appears to have a routed grove on the long edge, and its sides, all around, are slanted at an angle. How did you achieve that angle all around the contraption. Is that the "clapper" you mentioned?
FlyingSawdust is offline
post #14 of 21 (permalink) Old 01-17-2019, 10:48 AM
Very nice job, Jon. The pictures are very clear as to what you did and what materials you used. Do you have any sketches and dimensions available, and if so, would you care to share them. Thank you.
Herb Stoops likes this.
Potowner1 is online now
post #15 of 21 (permalink) Old 01-17-2019, 11:00 AM
TenGees's Avatar
First Name: Paul
Quilting jigs? Nice work, Jon. You better watch out, Kreg or Milescraft might cut in on your business!
JFPNCM, Herb Stoops and artman60 like this.
TenGees is offline
post #16 of 21 (permalink) Old 01-17-2019, 09:25 PM Thread Starter
JFPNCM's Avatar
First Name: Jon
@marecat3
I’ve thought about making one with an edge to hold an iPad. It would be a simple addition and if you don’t need it there all the time, I would attach it with a series of pencil sized magnets. By adding a couple in the base the edge could be secured when not in needed.
@FlyingSawdust
That is indeed the clapper. I routed the groove into the side with a bullnose bit before I rounded the ends which created the “angled” appearance. The ends were rounded on the bandsaw and then finished with an oscillating be,t sander.
marecat3 likes this.
Jon
JFPNCM is offline
post #17 of 21 (permalink) Old 01-17-2019, 09:44 PM Thread Starter
JFPNCM's Avatar
First Name: Jon
Thanks Rick. I don’t have and drawings per se, but hopefully the following dimensions will help:
The base and top: 1/2 x 8 x 12” Baltic birch plywood.
The vertical risers: 2 x 4 x 4” with one end of each rounded so they can pass over eac other easily
The cross pieces: 1/8 x 1 5/8 x 6” poplar with rounded ends although these dimensions depend on how you space the risers. The poplar came from the cutoff bin.
The cross bolts: 5/16 x 3” tee bolts. I added a star washer on the tee end as the bolts tended to slip on tightening and pieces of self sticking sand paper to the cross pieces to eleminate slippage as well
Standard star nuts picked based on feel.
The risers were centered on the base and place at least 1” back from the edge to allow for the covering.
Hopefully these dimensions help. Overall size could certainly be changed and an edge added depending on the use, such as holding an iPad.
MEBCWD and Herb Stoops like this.
Jon
JFPNCM is offline
post #18 of 21 (permalink) Old 01-17-2019, 10:09 PM
Nickp's Avatar
First Name: Nick
Jon...nicely done...you've made many happy faces...but...
You need to change the currency...those cookies are gonna turn into your Achille's heel...once hooked, you're done...
Now, I happen to run a currency exchange outfit where I will certainly entertain the notion of swapping your cookies for my useless bits of wood. Ya think...?
Herb Stoops and 1fizgig like this.
Nick
Nickp is online now
post #19 of 21 (permalink) Old 01-18-2019, 01:35 AM Thread Starter
JFPNCM's Avatar
First Name: Jon
@Nickp
As I recall it was having access to a few “useless bits of wood” that landed me in this predicament. ��
Thanks Nick.
Jon
JFPNCM is offline
post #20 of 21 (permalink) Old 01-18-2019, 06:22 PM Thread Starter
JFPNCM's Avatar
First Name: Jon
@Potowner1
Minor error in the description of the materials, the poplar was 1/4” not 1/8”
Jon
JFPNCM is offline
Simple solutions are always the best answer Gaffboat Jigs and Fixtures 16 10-30-2016 12:51 AM
Forum Suggestion Thread Mark Site Help and Suggestions 131 02-08-2015 10:33 AM
A Beginner's Simple Finish Jerry Bowen The Finishing Touch 4 07-15-2012 11:11 PM
Simple pin router Chris Curl Jigs and Fixtures 5 06-09-2012 11:51 PM
Keep It Simple ??? Drugstore Cowboy Lobby 5 07-31-2007 11:01 AM
