Aging Brass - Router Forums
 24Likes
  • 18 Post By Gaffboat
  • 1 Post By kp91
  • 2 Post By Herb Stoops
  • 1 Post By Holic46
  • 2 Post By gdonham1
post #1 of 5 (permalink) Old 03-03-2019, 11:58 AM Thread Starter
Gaffboat's Avatar
First Name: Oliver
Default Aging Brass
When I made my Fortune Teller project, I wanted everything to look as old and antique as possible. That meant I had to age the parts I made out of shiny new brass. You may find the technique helpful for projects where you have new hardware and would like it to appear aged.
A simple 50/50 solution of vinegar and hydrogen peroxide achieves the aged look in about 5 minutes or less. It helps speed up the process if you heat the liquid in the microwave to about the boiling point before putting your brass pieces into the solution.
The acidic vinegar attacks the surface of the brass and the peroxide oxidizes it. When done, your solution will begin to take on a greenish color because of the copper leeched from the brass. The 50/50 solution can be saved and used again later on other projects.
Here are samples of the aged Fortune Teller side plate, and a comparison of two small brass hinges where one was aged, and one was not.
Name:	1 Ingredients.jpeg
Name:	2 Zola side plate.jpeg
Name:	3 Hinges.jpeg
Name:	4 Aging process.jpeg
Name:	5 Used solution.jpeg
kp91, chessnut2, DaninVan and 15 others like this.
Gaffboat is offline
post #2 of 5 (permalink) Old 03-03-2019, 01:17 PM
kp91's Avatar
First Name: Doug
Great tip! Fun to experiment with how long it takes to get the color you want with all the different alloys.
Herb Stoops likes this.
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #3 of 5 (permalink) Old 03-03-2019, 01:23 PM
The first thing I threw away on my way back from the Army was the can of Brasso.
Just saying,
TenGees and Roy Drake like this.
Herb Stoops is online now
post #4 of 5 (permalink) Old 03-04-2019, 03:42 PM
When you heat up your solution in the microwave, do you leave the brass piece in the solution? That would speed up the process somewhat.
HAHAHA!
Holic46 is offline
post #5 of 5 (permalink) Old 03-05-2019, 01:37 AM
gdonham1's Avatar
First Name: Guy
Just be careful mixing chemicals. Some chemicals can put off poison gas and at the very least can damage your lungs. Probably best not to do this in your wife's kitchen.
Roy Drake and Herb Stoops like this.
gdonham1 is offline
Cutting thin brass to shapes rwl7532 Tools and Woodworking 26 01-29-2017 02:03 PM
Brass Set Bars bobj3 The Bargain Bin 6 03-10-2014 12:24 PM
Antique Brass MaxCohen Starting Off 6 12-05-2011 08:56 AM
Why do threaded guide bushings have right-handed threads sandyalexander Guide Bushings and Templates 30 02-23-2010 08:57 AM
brass inlays gregW General Routing 13 10-05-2009 06:20 PM
