Nelly the elephant - Router Forums
 38Likes
post #1 of 21 (permalink) Old 03-09-2019, 04:46 AM Thread Starter
sunnybob's Avatar
Country: Cyprus
First Name: Bob
Default Nelly the elephant
Had a very frustrating winter, far too many "real" jobs to do. But I finally got another box done.
Walnut, beech and ply.
Trouble is every time I make an animal shape to sell, the missus gets attached and wont let it go.
sunnybob is offline
post #2 of 21 (permalink) Old 03-09-2019, 06:59 AM
Gene Howe's Avatar
First Name: Gene
Can't blame your wife. Nelly is quite handsome.
Been trying to figure out how you cut the space between those legs without cutting into the trunk.
Gene Howe
Snowflake, AZ
Gene Howe is offline
post #3 of 21 (permalink) Old 03-09-2019, 07:20 AM Thread Starter
sunnybob's Avatar
Country: Cyprus
First Name: Bob
my new table saw. I'm enjoying learning what I can do with it.
sunnybob is offline
post #4 of 21 (permalink) Old 03-09-2019, 09:06 AM
Bob, great job on this box.
Would you mind sharing some dimensions. I am also trying to figure out how you cut out the legs and didn't bring a tear to NELLY'S eye (trunk).
Thanks for sharing
Potowner1 is offline
post #5 of 21 (permalink) Old 03-09-2019, 09:06 AM
Gene Howe's Avatar
First Name: Gene
Thanks, Bob.
Gene Howe
Snowflake, AZ
post #6 of 21 (permalink) Old 03-09-2019, 09:35 AM
My guess is the legs are the front and back of the box, which could be cut from the same or a sandwiched piece using a pattern. Use the pattern to cut the middle layered section to fit, but with the trunk, but without the legs. Glue the front together with the middle sections and do the bandsaw cuts, then glue the back piece on last. Sand to perfect the rounded shape and finish. At least that's one way to produce what is a very interesting band saw box. Nice work Bob, especially given the limited wood choices on the island.
post #7 of 21 (permalink) Old 03-09-2019, 09:35 AM Thread Starter
sunnybob's Avatar
Country: Cyprus
First Name: Bob
She's 11" x 8" x 4" wide.
I usually start with a drawing on an A4 sheet of paper.
It might have been a "he" before i cut the legs out though
I used the table saw set to the belly height, then ran the box along the fence, being very careful to lift the box off before it got to the trunk. I only have a thin kerf blade so I had to make about 10 cuts, moving the fence each time.
Then i used a power file and sandpaper to finish off.
I must admit I made a mistake on this, I originally was going to start high in the centre cut, and then progressively lower the blade and cut each direction each time so that I had an arch. But I got over excited playing with the new saw and forgot to lower the blade, making the leg gap more square than "plan A" had it.
thomas1389 and Herb Stoops like this.
sunnybob is offline
post #8 of 21 (permalink) Old 03-09-2019, 09:37 AM Thread Starter
sunnybob's Avatar
Country: Cyprus
First Name: Bob
Tom, just seen your post.
man, you give me way more credit for planning than I deserve
I start with a block of wood, and the rest is an ongoing saga.
DesertRatTom likes this.
sunnybob is offline
post #9 of 21 (permalink) Old 03-09-2019, 10:21 AM
Stoneface's Avatar
First Name: Frank
Bob,
Great job!!
Frank
Frank
Stoneface is offline
post #10 of 21 (permalink) Old 03-09-2019, 10:52 AM
Great job,Bob, you always do such fine work. I like it.
Herb Stoops is online now
Kindergarten logic and woodworking AshleyJ Lobby 10 01-03-2018 04:02 PM
Elephant on a drum Lee Brubaker Show N' Tell 8 05-12-2010 09:02 AM
