I need help identifying an old router. - Router Forums
 5Likes
  • 2 Post By twmv86
  • 1 Post By Nickp
  • 1 Post By ger21
  • 1 Post By Herb Stoops
post #1 of 10 (permalink) Old 04-07-2019, 11:14 PM Thread Starter
I would like to find the speed of an old router I picked-up years ago. The base (moter bracket) still has an ID tag that reads: Stanley type - model 92937.02. However I have not found anything for a Stanley router with that model. It takes a 1/2" bit.
I would like to know the speed of this router, so I can use it safely.
Thank you, Jay.
jayhawkins is offline
post #2 of 10 (permalink) Old 04-07-2019, 11:56 PM
JOAT's Avatar
First Name: Theo
OK, I'm puzzled. What does knowing what the speed is have to do with using it safely? I've got five old Craftsman routers, don't know the speed of any of them, and have used them safely for years.
JOAT is online now
post #3 of 10 (permalink) Old 04-08-2019, 01:16 AM Thread Starter
The larger the diameter of your router bit, the slower, lower rpm, it should spin. See chart in pic.
post #4 of 10 (permalink) Old 04-08-2019, 01:33 AM
First Name: n/a
looks like this from the 50s. possibly a Model H13B 8B. good luck finding the rpm. you can only slow it down for larger bits if its variable speed. let your neighbor try it first. thats all i got.
https://www.ebay.com/itm/Vintage-Sta...cAAOSw-YtbsCjC
https://www.ebay.com/itm/Booklet-For...MAAOSwLyVZ3Vv0
DaninVan and jj777746 like this.
twmv86 is offline
post #5 of 10 (permalink) Old 04-08-2019, 03:04 AM
It looks like the same as this router motor in an over head router. The cord seems to be mounter the same. It doesn't say the rpms, but they were around 15,000 rpms.
The ring around the body,and the dome are very similar to yours too.
Photo Index - Stanley Works, Stanley Electric Tools - OR5S BENCH MOUNT | VintageMachinery.org
Herb Stoops is online now
post #6 of 10 (permalink) Old 04-08-2019, 08:32 AM
Nickp's Avatar
First Name: Nick
It probably doesn't have the power to drive a huge bit, for example, panel bits anyway. You're likely to use bits up to an 1", maybe a bit bigger handheld or in a table so whatever its speed it's going to be less than the max of the bit.
If you're planning on spinning something like a panel cutter then this is not the router for it.
If you plan on using it for edge profiling (ogee, roundover, slot cutter, etc) it should be okay.
Make sure of other things like runout, bearing problems, shaft wear, etc... to make sure you minimize vibrations.
Also check brushes and commutator as dirty brushes may cause varying speeds which would not be good.
Good luck with it...
Herb Stoops likes this.
Nick
Nickp is offline
post #7 of 10 (permalink) Old 04-08-2019, 08:35 AM
Nickp's Avatar
First Name: Nick
Deleted text...placed in wrong thread...sorry
Nick
Nickp is offline
post #8 of 10 (permalink) Old 04-08-2019, 01:51 PM
ger21's Avatar
First Name: Gerry
ger21 is offline
post #9 of 10 (permalink) Old 04-08-2019, 03:32 PM
I agree with everything that Nick said, Do not try to use large bits in this router. In the time period these were used, they did all the larger profiles with a shaper. Routers were designed at first to routing small profiles by a hand held machine. They are under rated compared to modern routers, and will not hold up to the large bits produced today.
DaninVan likes this.
post #10 of 10 (permalink) Old 04-15-2019, 01:09 AM Thread Starter
Hey thanks guys. These are some good thoughts. I was thinking it might be a M1-a, R5A or R5B, maybe a R518. And with the grey-green paint, it might be from the 60s.
A couple guys at a wood-working store suggested that it might be running at 18,000 rpm (or possibly higher). Only the R518 moves slow enough to be OK.
Regardless, I'm not comfortable putting a 2-1/4" bit in this old router. It is for slot cutting some flooring. Great tips on the bearings, shaft wear and vibrations.
wingless' Craftsman 171.25475 Router Table Restoration / Upgrade wingless Table-mounted Routing 8 03-30-2019 08:51 AM
First mount your router.... SimonHartropp Table-mounted Routing 6 09-08-2015 02:39 PM
Sort Members by City or Zip RJM60 Site Help and Suggestions 56 03-13-2014 06:40 PM
Motorized Router Lift - Eagle Lake Style johnwnixon Table-mounted Routing 14 05-23-2012 05:51 PM
