I'm Cutting Corners - Page 2 - Router Forums
 27Likes
post #11 of 13 (permalink) Old 05-07-2019, 11:00 AM
Originally Posted by honesttjohn View Post
The mind/memory is the second thing to go when you get older!!
What's the first; I can't remember?
DaninVan is offline
post #12 of 13 (permalink) Old 05-07-2019, 04:22 PM
sreilly's Avatar
First Name: Steve
Originally Posted by harrysin View Post
Well done Colin, right up to the last shot I assumed that you didn't have a lathe! Why didn't you just pop it into the lathe and with a decent size gouge turn it down to size in next to no time?
Is there a Genie in there Harry?
sreilly is offline
post #13 of 13 (permalink) Old 05-07-2019, 06:50 PM
JOAT's Avatar
First Name: Theo
[QUOTE=Coleve;2016909]JAs you can see, I used my newly sharpened chisels and turned the front to accept a copper ferrule which being a plumber is a cutting of 22mm 3/4inch copper supply pipe which i coated with epoxy and forced home on my vice. [QUOTE]
When I do that I use the brass end of a fired 12 ga shotgun shell. Works nicely.
gomolajoe and tulowd like this.
Of course I'm not busy, I did it right the first time.
Call me a craftsman, artisan, or artistic, and I will accept that. Call me an artist and you will likely get a quite rude comment in return. I am not a @#$%ing artist.
JOAT is online now
One more cutting board JFPNCM Show N' Tell 19 03-13-2019 06:42 PM
Which bits... a deep rabbit hole... AshleyJ Router Bits - Types and Usage 15 03-10-2018 08:36 PM
spiral bit for cutting plywood calneva Router Bits - Types and Usage 11 09-28-2017 06:25 PM
Cutting out Circles and Arcs the Easy Way learnexperience Portable Routing 1 11-26-2011 01:29 PM
New router and which starter router bits for my useage? Skyglider Router Bits - Types and Usage 11 12-08-2010 09:42 PM
