Another box - long-leaf maple burl - Page 2 - Router Forums
 33Likes
post #11 of 24 (permalink) Old 09-12-2019, 07:46 AM
sreilly's Avatar
First Name: Steve
Simply beautiful. I would have never guessed you could get that wood out of that burl. Who wouldn't want a box like that? I'd buy something just to put in it.
sreilly is online now
post #12 of 24 (permalink) Old 09-12-2019, 08:28 AM
Gaffboat's Avatar
First Name: Oliver
Wow!
Gaffboat is offline
post #13 of 24 (permalink) Old 09-12-2019, 08:57 AM
First Name: Al
Inspirational...
HoweA is offline
post #14 of 24 (permalink) Old 09-12-2019, 09:24 AM
TenGees's Avatar
First Name: Paul
Beautiful box, Malcolm. Just amazing wood grain with a perfect finish. I've tried using "finishing nail" hinges. Luckily I put the nails in with the lid in the closed position because wide open the lid is out of whack a little. It was just a box for clothespins though, not anywhere near the class of your build.
TenGees is online now
post #15 of 24 (permalink) Old 09-12-2019, 10:02 AM
Honored Member
harrysin's Avatar
First Name: Harry
There's nothing that I can add to all of the above compliments.
Harry
harrysin is offline
post #16 of 24 (permalink) Old 09-12-2019, 10:03 AM
Absolutely beautiful. It looks like your corners are mitered. Did you do anything to reinforce the miters.
olliecooper is offline
post #17 of 24 (permalink) Old 09-12-2019, 10:46 AM
Remarkable!!!
You are a real artisan.
Potowner1 is offline
post #18 of 24 (permalink) Old 09-12-2019, 11:04 AM
First Name: Don
Send a message via AIM to Jimmy Dee Send a message via Yahoo to Jimmy Dee
Malcolm,
Beautiful! I have never worked with burls. How did you make the initial cuts and get the burl into workable pieces?
Don
Jimmy Dee is online now
post #19 of 24 (permalink) Old 09-12-2019, 11:40 AM Thread Starter
kywoodchopper's Avatar
First Name: malcolm
For the mitered corners, I just put Titebond II glue and left it clamped up for 24 hours to ensure the glue was cured.
As far as working with the wood..as I said a friend used a chainsaw to cut several pieces. I use the jointer that has spiral cutter head to smooth the wood. The pieces that I was working with were probably 2" thick on one edge and 3" thick on the other. I decided which side had the best grain and after flattening that side and an edge to go with it I ran it through the bandsaw to slice off boards. The planer that I used (DeWalt 735) also has a spiral cutter head. Otherwise the wood would have gotten torn badly.
jw2170, CharleyL, JFPNCM and 4 others like this.
kywoodchopper is offline
post #20 of 24 (permalink) Old 09-12-2019, 12:10 PM
David Bradford's Avatar
First Name: David
That is a great looking box, I love the figure in that piece.
David Bradford is offline
