Another box - long-leaf maple burl - Router Forums
 33Likes
post #1 of 24 (permalink) Old 09-11-2019, 06:02 PM Thread Starter
kywoodchopper's Avatar
First Name: malcolm
Default Another box - long-leaf maple burl
I lady friend asked that I make her a box to put her favorite Bible in. I examined several species of wood before settling on long-leaf maple burl that I had gotten several years ago. The top pivots on two finishing nails (cheap hinges). The finish is my usual stuff - Zar oil-base polyurethane diluted 50/50 with mineral spirits that is applied with the blue paper shop towels that are cut into 1/4s.
I applied 4 or 5 coats - waiting about 8-hours between coats. Then I applied a heavy coat of the same material using a 1" foam brush. I use 400 grit sandpaper on a random orbital sander running at 1/2 speed. I applied the finish to the sandpaper as well. After sanding for 30 seconds on one of the sides, I wiped that piece down with a blue shop towel and rotate the unit to do another side. After 8-hours I started back applying more finish. Probably has 10 coats. I didn't attach the top until after all coats were applied.
I made a jig to indicate where to drill the holes in the sides for the finishing nails to go through. For that I had to experiment.
I will give the lady the box this weekend.
Malcolm / Kentucky USA
kywoodchopper is offline
post #2 of 24 (permalink) Old 09-11-2019, 08:14 PM
difalkner's Avatar
First Name: David
As usual, that's just beautiful, Malcolm! Good job.
David
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is online now
post #3 of 24 (permalink) Old 09-11-2019, 08:56 PM
Just Super!!!
HJ
Detroit Burbs
RoutervilleUSA on Etsy
honesttjohn is offline
post #4 of 24 (permalink) Old 09-11-2019, 09:06 PM
Wow ,I have never seen a burl that large, Malcolm, just absolutely beautiful. You did an exceptional job ,as usual, she should be happy with it. A fiitting use for that beautifully figured wood.
MEBCWD and sreilly like this.
Herb Stoops is online now
post #5 of 24 (permalink) Old 09-11-2019, 09:17 PM
kp91's Avatar
First Name: Doug
You definitely know how to showcase the natural beauty of the wood. Great job
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #6 of 24 (permalink) Old 09-11-2019, 09:59 PM
My gosh, that is really beautiful. The straight lines set of the swirls in the burl, which was a gigantic thing indeed.
post #7 of 24 (permalink) Old 09-11-2019, 10:03 PM
Beautiful, Malcolm....
I can see why she asked you to make the box....
Herb Stoops likes this.
Sydney, Australia
jw2170 is offline
post #8 of 24 (permalink) Old 09-11-2019, 10:54 PM
old coasty's Avatar
First Name: Bob
Finest Kind as they say down east in Maine
" Age is an issue of mind over matter. If you don't mind it doesn't matter. "
Mark Twain
old coasty is offline
post #9 of 24 (permalink) Old 09-12-2019, 12:56 AM
That was quite a burl. Nice job.
post #10 of 24 (permalink) Old 09-12-2019, 06:33 AM
First Name: mary
so lovely
marecat3 is offline
