Beatnik Bike Crate - Router Forums
 11Likes
post #1 of 11 (permalink) Old 09-27-2019, 02:08 PM Thread Starter
First Name: Jamie
Default Beatnik Bike Crate
A real beatnik on a cruiser bike picks up an old pop crate out of the trash and straps it on with bungie cords. I decided to complicate it as much as possible. My wife wanted a crate to hold a travel mug and coat. Not too big or heavy. I decided to use red cedar for lightweight and to handle the rain. Crate building is boring so I decided to build my slats like hand cut dovetail drawers. The cedar surprisingly took a cut well and chiseled ok. Finished the my crate with 5 coats of shellac. Rubbed it down with steel wool and wax to knock the sheen down. This bike rarely sees rain so I figure it will hold up ok with shellac. Used brass cap screws with wing nuts for quick removal. Those with a good eye will see my mistake on the base. I forgot and cut my base groove right through my dovetails. Plugged my holes with scraps.
jemangin is offline
post #2 of 11 (permalink) Old 09-27-2019, 11:19 PM
First Name: thomas
Now that's not just any old pop crate! Nice job, Jamie.
thomas1389 is online now
post #3 of 11 (permalink) Old 09-28-2019, 01:16 AM
Nothing wrong with that, Good job.
Herb Stoops is online now
post #4 of 11 (permalink) Old 09-28-2019, 06:27 AM
Stoneface's Avatar
First Name: Frank
Great idea Jamie.
Frank
Frank
Stoneface is offline
post #5 of 11 (permalink) Old 09-28-2019, 08:22 AM
sreilly's Avatar
First Name: Steve
Jamie those "added features " look great. Best looking create I've seen posted.
sreilly is offline
post #6 of 11 (permalink) Old 09-28-2019, 10:42 AM
CharleyL's Avatar
First Name: Charley
Shellac and water don't go together well at all.
I think it's good looks will last much longer if you put several coats of polyurethane on top of the shellac. Sand the surfaces with 0000 grade steel wool or a fine grade of Scotch Brite pad, and blow off the surfaces well before each application. The micro fine scratches will make the poly adhere better.
Charley
Central North Carolina
CharleyL is offline
post #7 of 11 (permalink) Old 09-28-2019, 11:54 AM Thread Starter
First Name: Jamie
Good advice. I have some oil based minwax poly. I'll put a few coats on.
jemangin is offline
post #8 of 11 (permalink) Old 09-29-2019, 07:38 AM
Nickp's Avatar
First Name: Nick
Nice crate...looks good on the bike...
You may want to consider spar varnish for the finish...moves better with changes in the wood, sun, heat, cold, etc...
Nick
Nickp is online now
post #9 of 11 (permalink) Old 09-29-2019, 08:08 AM
will spar hold up to the elements really well???
post #10 of 11 (permalink) Old 09-29-2019, 09:15 AM
papasombre's Avatar
Country: Venezuela
First Name: Alexis
Hi, Jamie.
Very nice job. The bike looks much the better now.
We, woodworkers are everywhere!!!
papasombre is offline
