new drill press and pancake compressor cart - Router Forums
 27Likes
post #1 of 27 (permalink) Old 12-18-2019, 04:57 PM Thread Starter
roofner's Avatar
First Name: Gary
Default new drill press and pancake compressor cart
Here is basic cart frame for new drill press.
roofner is offline
post #2 of 27 (permalink) Old 12-18-2019, 05:03 PM
Semipro's Avatar
First Name: John_*
I see the new cart where is the new drill press?
Semipro is online now
post #3 of 27 (permalink) Old 12-18-2019, 05:18 PM
and compressor
Stick486 is offline
post #4 of 27 (permalink) Old 12-18-2019, 05:21 PM Thread Starter
roofner's Avatar
First Name: Gary
It's sitting on my work bench. However I did use it to build this frame. I drilled the holes for the carriage bolts that holds frame together. Really pleased with drill press used the stop block on my Rockler auxiliary top to locate holes.
Stick486, Semipro and Herb Stoops like this.
roofner is offline
post #5 of 27 (permalink) Old 12-19-2019, 08:05 AM
Bushwhacker's Avatar
First Name: David
I for one would like to see the finished cart.
What is that white stuff piled up against the house?
I have nothing but respect for any of you guys that will get out in the winter cold to work on projects.
I started my cutting board project yesterday and did it in increments. From the shop to the house to get warm
and it was 60 degrees. But I wore my jacket and gloves.
Hang in there Gary
David
When the enemy is in range, so are you.
Bushwhacker is offline
post #6 of 27 (permalink) Old 12-19-2019, 05:35 PM Thread Starter
roofner's Avatar
First Name: Gary
Well it was high of 19 today no work here today. It has to be at lest in the 40 for me to work. I have only 1 complaint with the drill press the handle hits the back of the auxiliary table. I clamp the auxiliary table to the back edge of table and drew a centered line . I measured the distance from the center line to the front of auxiliary table and added a 1/4 inch . Then cut a block the width of the sum plus 1/4 inch and the width of drill press table . Then screwed to the center of the auxiliary table. Here is what impressed me with the dill press . I drilled the holes half through and flipped the piece over finished drilling . The holes were perfectly straight. The drill press was square out of the box.
DesertRatTom and Herb Stoops like this.
roofner is offline
post #7 of 27 (permalink) Old 12-22-2019, 05:21 PM Thread Starter
roofner's Avatar
First Name: Gary
Here is the latest picture finally got a warm day.
roofner is offline
post #8 of 27 (permalink) Old 01-04-2020, 09:56 AM Thread Starter
roofner's Avatar
First Name: Gary
Default Neeed help
Should I use 3/8 bolts to fasten the drill press? Is 2 enough or should there be 4? Should I put 2 or 3 brace in the back to keep from racking?
Should I use carriage bolts?
roofner is offline
post #9 of 27 (permalink) Old 01-04-2020, 10:25 AM
full back and 4 bolts...
ledger the back sheet of ply in...
Ray Newman and DesertRatTom like this.
Stick486 is offline
post #10 of 27 (permalink) Old 01-04-2020, 12:01 PM
Agree on putting on a back. Otherwise it's a nice use of space. If you're going to put castors on it, I suggest using two fixed ones on the back and two locking swivels on the front. Make sure the swivel locks the tires and the swivel at the same time.
