Live Edge Waterfall Stool with through tusk tenon - Router Forums
 19Likes
  • 16 Post By jemangin
  • 3 Post By jemangin
post #1 of 8 (permalink) Old 12-22-2019, 06:01 PM Thread Starter
First Name: Jamie
Default Live Edge Waterfall Stool with through tusk tenon
It may have turned into an end table but it did start out as a stool for putting on your shoes in my mind. I had one live edge big leaf maple plank left from my bigger bench project(a work in progress) and decided to make a Xmas present for my in laws. I have always wanted to try out a waterfall miter and a tusk tenon so I put them both in. I almost added a dovetail joint as well but fortunately I came to my senses.
Working with live edge was a great experience. You don't realize how much you depend on those 6 square and true edges till you don't have them. The miter was reinforced with dominos as was the stretcher and leg. Kind of felt like I was cheating using the domino but I used my limited Xmas time frame as an excuse. My bench is going to be all old school.
The tusk tenon was quite easy after I found a great article in FWW. The stool is actually stable in spite of the wonky shaped legs. Finished it with 6 coats of shellac then steel wool and wax.
Jamie
jemangin is offline
post #2 of 8 (permalink) Old 12-22-2019, 06:55 PM
nicely done..
post #3 of 8 (permalink) Old 12-23-2019, 06:25 AM
sreilly's Avatar
First Name: Steve
Ya done good Jamie. They'll love that table for sure. Look like you used your Domino for the miter joint, well done. Lets see some pictures of your "in progress" project when you can.
sreilly is offline
post #4 of 8 (permalink) Old 12-23-2019, 08:37 AM
Chris Itin's Avatar
First Name: Chris
VERY nice!!!
Getting old ain't for sissies.
Chris Itin is offline
post #5 of 8 (permalink) Old 12-23-2019, 01:10 PM Thread Starter
First Name: Jamie
Was in such a hurry I didn't take very many in progress pictures. Here are a few. The miter joint was reinforced with 5 by 30 mm dominos which I had to cut short. The stretcher was held with a 8 mm by 50 mm domino. I was going to do a through wedged tenon but decided I didn't want to break up the waterfall look on that end.
This stool was made from the left overs of my two maple planks. The best part of the planks was used for a bench seat. Hoping to finish my bench in January. I included pictures of the original planks and the finished bench seat.
jemangin is offline
post #6 of 8 (permalink) Old 12-24-2019, 01:47 AM
you did a good job on that , Jamie, I have never seen a one ended wedge tenon like that, but good idea, and i understand why you did that.
I like your work.
Herb Stoops is offline
post #7 of 8 (permalink) Old 12-27-2019, 07:02 AM
First Name: Bogdan
Very nice!
topielski is offline
post #8 of 8 (permalink) Old 12-27-2019, 01:58 PM
First Name: Will
Great job; eye-catching...
WI1L is offline
