Bedside Shelf - Router Forums
 12Likes
post #1 of 15 (permalink) Old 01-20-2020, 12:38 PM Thread Starter
Stoneface's Avatar
First Name: Frank
Default Bedside Shelf
Completed next project for wife which was a Bedside Shelf. I took more pictures this time so you can see the process. It started with a cad drawing because I had to design it to fit by the bed. It needed to have a place to hold wife's phone and to have Kleenex built in. The rest was shelves. Was going to make it plain, but decided to add hearts to sides and bottom front.
The first picture is the cad drawing. The second picture show the cut list I make in Excel. Since I am re-sawing and making my own boards, it helps me keep track of what I have made. Using the heart design I made in CAD and printed, I used spray adhesive to attach to scrap board. I then drilled out the waste and used a jig saw to cut out the heart shape to be used with the router, see 4th photo. In photo three, I pre-drilled out the waste on the shelf sides. I the 5th photo, I attached the template to the side and used the router to make each heart. The 6th photo shows the completed hearts on both sides.
The 7th photo shows the dado jig I used for each shelf. I used blind dado's which stopped 1/2" from the front edge. I did not want the dado to show from the front. See photo 8 to see dado's and shelves. Photo 9 shows the shelves being glued to one side. I wanted to be sure that they were square to the side. You can never have too many clamps!!!
Photo's 10 & 11 show the final product, front and back. The trap door at the top is where you will put the Kleenex box in and turn the knob to hold the door shut. The knob was made by cutting a dowel rod in half.
Finally photo 12 is the final project after three coats of Satin Urethane.
Frank
Frank
Stoneface is offline
post #2 of 15 (permalink) Old 01-20-2020, 12:51 PM
RainMan 2.0's Avatar
Nice job Frank . That looked like a lot of work, but certainly paid off .
Ok ,I never insulate
RainMan 2.0 is offline
post #3 of 15 (permalink) Old 01-20-2020, 06:23 PM
great tutorial..
w/ better results...
jj777746 likes this.
post #4 of 15 (permalink) Old 01-20-2020, 08:28 PM
old55's Avatar
First Name: Ross
Nice one.
Ross,
old55 is offline
post #5 of 15 (permalink) Old 01-20-2020, 09:25 PM
That is a really great project. Very attractive bit of woodworking, and a really nice tutorial. You also proved the old saying that you can never have too many clamps. I particularly like the heart shaped cutouts.
post #6 of 15 (permalink) Old 01-21-2020, 06:32 AM Thread Starter
Stoneface's Avatar
First Name: Frank
Tom,
I found a way to create the heart shape in the CAD drawing system using a box and two circles. Using the “trim” function, I remove the lines not needed and you have a heart and when printed full size a paper copy to make template. When I created the smaller heart on the bottom front, I made it too large. Found the “shrink” command and made it fit.
Thanks to everyone for kind comments.
Frank
Frank
post #7 of 15 (permalink) Old 01-21-2020, 06:40 AM
First Name: mary
very nice space saver
marecat3 is offline
post #8 of 15 (permalink) Old 01-21-2020, 08:10 AM
Bstrom's Avatar
First Name: Brian
You nailed the finish color match to your bed - well done! Also like your assembly pix - keeping the dividers square with those blocks is a good approach.
I really envy you CAD users - I shoulda added that to my computer skills a good while ago - is there an 'easy' 2D version for beginners that won't take forever to learn?
Common Man Woodworking
Powell, TN
Bstrom is offline
post #9 of 15 (permalink) Old 01-21-2020, 11:29 PM
TenGees's Avatar
First Name: Paul
Nice job and nice post, Frank.
TenGees is online now
post #10 of 15 (permalink) Old 01-22-2020, 07:01 AM Thread Starter
Stoneface's Avatar
First Name: Frank
Brian,
I use AutoCad which is very expensive. You can get Sketchup for free. I started using it and still have it, but mainly use AutoCad.
Frank
Frank
