Drill Press Table - Router Forums
 27Likes
post #1 of 14 (permalink) Old 02-12-2020, 09:22 PM Thread Starter
First Name: Roger
Default Drill Press Table
Here is what I just made for my drill press it makes it easier to make duplicate items adjustable fence with stop blocks and T-Track for hold downs and slots for using F-Clamps. center circle is replaceable for when it gets buggered up when drilling. Up down and lock cranks are extended to either side. Original plans called for miter gears for height adjustment in the front but factory shaft on press was 1/8" out of round and gears wouldn't stay meshed. Still need to stain and polyurethane.
Rogerv is offline
post #2 of 14 (permalink) Old 02-12-2020, 09:31 PM
rock solid and I like it..
jj777746 likes this.
post #3 of 14 (permalink) Old 02-12-2020, 10:01 PM
Great table. Very well thought out and executed. My DP has a wiggly table with play side to side, so I have to align it with the bit whenever I change height. Fortunately, the WEN DP projects a laser crosshair that is very accurate for alignment purposes. I like the T track on the sides and fence, and the circular insert is very cool.
DesertRatTom is online now
post #4 of 14 (permalink) Old 02-12-2020, 10:09 PM
RainMan 2.0's Avatar
Great job Roger , and a great idea for a project .
Ok ,I never insulate
RainMan 2.0 is online now
post #5 of 14 (permalink) Old 02-12-2020, 10:13 PM
old55's Avatar
First Name: Ross
Nice job.
Ross,
old55 is offline
post #6 of 14 (permalink) Old 02-12-2020, 10:25 PM
PhilBa's Avatar
First Name: phil
Looks well done. A better table has been on my list forever, longer than insulation projects. The thing stopping me is I need to swap between a fence and a cross slide vise. Swapping is a real PITA so I have to figure out a super fast method. Seeing this is kind of remotivating me.
Visit my shop website.
PhilBa is offline
post #7 of 14 (permalink) Old 02-13-2020, 06:35 AM
Bstrom's Avatar
First Name: Brian
I struggled with the same issue and chickened out on making a 'better' press type table - I ditched the original configuration and built a rolling cart with an adjustable set of shelf brackets - then added a Chinese XY vise that has been the mainstay ever since. Two different chunks of pine are chocked into the vise that quickly get me within range with the drill bit bore stroke needed and I can knock out accurately located holes in minutes with minimal hassle.
Nonetheless, that is one pretty table conversion and the build quality is obvious - hope it serves you well, Roger!
Common Man Woodworking
Powell, TN
Bstrom is online now
post #8 of 14 (permalink) Old 02-13-2020, 07:22 AM
sreilly's Avatar
First Name: Steve
Roger look likes a solid table. I also have been wanting to replace the one I had bought with a sturdy one. Mine is particle board I think with a laminate on it but only 3/4" thick and the rails were screwed in with maybe 1/4" screws that really don't hold especially in particle board. It also has a fence that goes maybe 3/4 of the way across. It's just plain week.
The other issue with mine is I had to install a boat trailer jack to raise and lower the table as it was both awkward and heavy. The old Clausing 1633 drill press doesn't have the tracked post for raising/lowering it easily. Now if I could find a retro kit I'd do that in a minute.
I was hoping that the sliding table I'm building would be able to be used on the DP as well but taking the PM701 mortiser on and off is just too heavy. Maybe a new DP table like this is in the cards after all.
sreilly is online now
post #9 of 14 (permalink) Old 02-13-2020, 08:14 AM
bryansong's Avatar
First Name: bryan
Very nice work Roger.
bryansong is offline
post #10 of 14 (permalink) Old 02-13-2020, 10:21 AM
Nickp's Avatar
First Name: Nick
Excellent...great idea to "remote" the handles...!
Is there any way you could key the gear, put a push spring in front of it and let it slide "to n' fro" at its heart's desire...? Then it will take up its own slack...
Nick
Nickp is online now
