Foyer Bench with Live edge seat and bit of Danish Modern - Router Forums
 18Likes
  • 17 Post By jemangin
  • 1 Post By jemangin
post #1 of 10 (permalink) Old 03-01-2020, 01:54 PM Thread Starter
First Name: Jamie
Default Foyer Bench with Live edge seat and bit of Danish Modern
This is my version of a bench I saw a picture of on pinterest by Nigel Alcorn. I changed up the joinery and the seat but stayed with his lines and leg/arm design.
I bought two very rough 4/4 big leaf maple slabs 7 years ago on kjiji and have been trying to find the right project for them ever since. They required some hole filling and strengthening with epoxy and eventually I had to say “flat enough” or risk having nothin left. I went with quarter sawn cherry for the frame which I cut from two large 8/4 rift sawn boards from the same tree.
The angled bridle joints were made using a tenon jig on the table saw. On Nigel’s bench he joined the stretchers with half laps to the sides. It broke up the flowing grain so I decided to go with dual dominos at those joints instead. This was my first project dealing with angles. I made a full size drawing of the leg/arm which really helped avoid mistakes. I was a bit worried about the strength of that arm but it turned out rock solid. Can't flex it even with full weight on the back corner.
I joined the seat to the bench frame with oversized screw holes then slotted them to allow for wood movement in the slab. The back rest is joined by a few dominos down the centre. It will be able to move away from the midline.
Finished it with 7 coats of super blonde shellac then steel wool and wax.
Everyone in the family has sat on it and no one has yet got there butt stuck in the seat crack!
jemangin is offline
post #2 of 10 (permalink) Old 03-01-2020, 02:23 PM
RainMan 2.0's Avatar
That turned out great . The crack makes it imo . Good job
Ok ,I never insulate
RainMan 2.0 is online now
post #3 of 10 (permalink) Old 03-01-2020, 03:54 PM
Bstrom's Avatar
First Name: Brian
I fully agree - itís gorgeous. Congrats on overcoming whatever challenges you faced. A real triumph...
Common Man Woodworking
Powell, TN
Bstrom is online now
post #4 of 10 (permalink) Old 03-02-2020, 06:55 AM
First Name: Larry
Very nice
Knot working is offline
post #5 of 10 (permalink) Old 03-02-2020, 07:19 AM
Chris Itin's Avatar
First Name: Chris
Simply beautiful. And beautifully simple in its lines. Great job.
Getting old ain't for sissies.
Chris Itin is offline
post #6 of 10 (permalink) Old 03-02-2020, 02:02 PM
Ed3443's Avatar
First Name: Ed
Jamie--that bench is stunning. Just WOW. I really love it. Would you be willing to provide dimensions and a write-up on the construction? You did a really amazing job. It is a beautiful piece of furniture.
Ed3443 is offline
post #7 of 10 (permalink) Old 03-03-2020, 12:51 PM
First Name: mary
very cool
marecat3 is offline
post #8 of 10 (permalink) Old 03-09-2020, 06:16 PM Thread Starter
First Name: Jamie
Overall dimensions ended up 20" front to back at bottom leg. 25 5/8" tall at the top of the armrest. 47 3/8" wide. The frame is 1 3/4" square. The angle of the legs is 8.5 degrees. I drew a full size drawing of the side profile first starting with the 20" bottom rung then drew 8.5 degree legs up from there till I got to my desired seat height of 17 3/4". The pictures are of the bench I found on pinterest and my notes changing the joinery. I also changed the back support. If you need anything else let me know.
Jamie.
Ed3443 likes this.
jemangin is offline
post #9 of 10 (permalink) Old 03-09-2020, 07:39 PM
First Name: Jessie
Wow, that's a nice piece!
Thanks for sharing it.
newbie2wood is offline
post #10 of 10 (permalink) Old 03-10-2020, 02:24 AM
First Name: Randy
That's gonna be a family heirloom. One of a kind design. Very nice.
ranman is offline
