Walnut picture frame of the grandsons - Router Forums
 24Likes
post #1 of 13 (permalink) Old 03-05-2020, 11:10 AM Thread Starter
dirt_dobber's Avatar
First Name: Randy
Default Walnut picture frame of the grandsons
Picture frame of the triplet grandsons (age 7)*
I used some Walnut I had laying around and added some Maple splines - used my
spline jig to cut in the corners (turned out a bit to thick (covering an error;-)
Sanding - 80, 120, 150 then 220 grit all around (I stop at 120 on the*back of frame)
prior to applying the finish I wet a*rag w/water and wipe down the wood - doing
that seems to raise the*grain a bit and then do a final 400 grit sand.
Finishing: my take on the "Sam Maloof type" finish
1/3 Boiled Linseed Oil
1/3 Wipe on Poly
1/3 paint thinner
SOP is to rag on the finish, let is sit for a few minutes, then wipe off the first coat or two
and after an hour*I wet/dry sand paper.*
Then 2 more coats get ragged on and wiped off without the sanding.
after 1 day dry time I then apply Johnson's paste wax.*
Making sawdust regularly, occasionally a project is completed.
dirt_dobber is offline
post #2 of 13 (permalink) Old 03-05-2020, 11:19 AM
Good job Randy, it came out really nice, and good looking grandsons.
dirt_dobber likes this.
Herb Stoops is online now
post #3 of 13 (permalink) Old 03-05-2020, 11:49 AM
difalkner's Avatar
First Name: David
Very nice, Randy! I have never tried that finish but have thought about it many times and you've presented a fine example on this frame, which is also well made. And yes, the grandsons are handsome, good looking young men!
David
Herb Stoops and dirt_dobber like this.
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is online now
post #4 of 13 (permalink) Old 03-05-2020, 12:00 PM
PhilBa's Avatar
First Name: phil
Error not, I rather like the look of those big ol fat splines. May borrow the idea for future project.
I'm interested in how your BLO finish performs over time. I did something similar on a live edge table top and got some darkening over several years. Not that it looks bad, just hard to control how much darkening will occur.
Visit my shop website.
PhilBa is offline
post #5 of 13 (permalink) Old 03-05-2020, 12:06 PM
most excellent...
post #6 of 13 (permalink) Old 03-05-2020, 02:01 PM
Oscar36's Avatar
First Name: Oscar
Good looking miters, frame and grandsons. Not in that order.
Oscar36 is offline
post #7 of 13 (permalink) Old 03-05-2020, 02:01 PM
RainMan 2.0's Avatar
Beautiful and then some. The spline makes it for me
Ok ,I never insulate
RainMan 2.0 is online now
post #8 of 13 (permalink) Old 03-06-2020, 07:04 AM
First Name: Larry
Good looking Grandson and the frams not bad either
Knot working is offline
post #9 of 13 (permalink) Old 03-06-2020, 07:06 AM
Stoneface's Avatar
First Name: Frank
Randy,
I always use walnut in my projects. I really like the finish. Excellent job and good looking boys.
Frank
Frank
Stoneface is offline
post #10 of 13 (permalink) Old 03-06-2020, 04:14 PM
bryansong's Avatar
First Name: bryan
Nice job Randy, I like walnut too.
bryansong is offline
