True relief in these trying times - Router Forums
 23Likes
post #1 of 11 (permalink) Old 03-31-2020, 03:32 PM Thread Starter
First Name: Doug
Send a message via Skype™ to vzbingo
Default True relief in these trying times
Many areas can't find Toilet Paper, but there's a replacement for residential TP - Commercial TP! Just have to be sure to get the two layer embossed type. Look at the ratings before buying. And then build this.
Itís 21.25Ē x 9.5Ē for the back and however for the bottom.
Cut a 4.75" radius on the back.
You can use the same size disc for both the base and the open end of the can, that way you only need 1 or 2 screws to hold the can on back.
Use a 1/4" bolt long enough to give you 3/4" length on the inside of the outer disc to hold the plastic face on, a tee nut on the outside would be a good way to secure the bolt if it recesses below the outside surface of the open end disc.
The plastic is 3/16" minimum thickness cut to 7" wide x 9" high. I drilled the bolt hole @ 2" from the right and 5" down. Cut the radius and sand to smooth it. The right edge is beveled with the back edge wider than the front and left rough to act as a tearing strip, but smoothed from the bolt hole down to the bottom for safety.
Place the plastic on the bolt in a vertical position, tightened with the knob. Using a 1/8" drill bit, drill a hole in the plastic and wood disc 1/3" or so from the top of the wood disc. Remove the plastic and put a round head screw in the wood disc hole, tightened down.
Using a 5/16" bit, carefully drill into the plastic in the 1/8" hole to ream out enough room for the screw head. This will lock the plastic in place when the paper is torn.
Finish as desired.
Place the paper on the tin can hub, then the plastic and knob.
Use as needed.
JFPNCM, difalkner, MEBCWD and 4 others like this.
Creator of high grade sawdust and artistic glue spots
"Opportunity is missed by most people because it is dressed in overalls and looks like work." T. Edison
vzbingo is offline
post #2 of 11 (permalink) Old 03-31-2020, 03:55 PM
mimac's Avatar
First Name: Brian
Good idea Doug. Can you get it with a power feed?
MEBCWD, vzbingo and RainMan 2.0 like this.
mimac is online now
post #3 of 11 (permalink) Old 03-31-2020, 04:21 PM
Nickp's Avatar
First Name: Nick
Great idea to consider the commercial stuff...nice job on the holder...
Nick
Nickp is offline
post #4 of 11 (permalink) Old 03-31-2020, 04:55 PM
Marco's Avatar
I 'm too lazy and took the easy way out.
kp91, MEBCWD, vzbingo and 3 others like this.
Galatians 5:13
Marco is online now
post #5 of 11 (permalink) Old 03-31-2020, 06:07 PM
CharleyL's Avatar
First Name: Charley
I think before the lock-up, everybody was doing it at work, using the commercial TP while also on the clock getting paid to sit there. Now with everybody at home 24/7 there is a greater need for the non commercial version. I know some are hoarding it, but it doesn't seem to explain the total demand. If the commercial version is readily available, my theory might be correct.
Charley
Gene Howe and Scap like this.
Central North Carolina
CharleyL is offline
post #6 of 11 (permalink) Old 04-01-2020, 11:56 AM Thread Starter
First Name: Doug
Thanks Nick. Figured someone may have a need and that's why it's here.
vzbingo is offline
post #7 of 11 (permalink) Old 04-01-2020, 11:58 AM Thread Starter
First Name: Doug
Brian, I thought about that but figured it's an easy way to get a buzz (short circuit). Besides, my cat can provide enough power if I let him.
mimac and Herb Stoops like this.
vzbingo is offline
post #8 of 11 (permalink) Old 04-01-2020, 12:28 PM
Charley
Looks like Amazon has some.
https://www.amazon.com/commercial-to...l+toilet+paper
Herb Stoops is online now
post #9 of 11 (permalink) Old 04-02-2020, 05:40 AM
papasombre's Avatar
Country: Venezuela
First Name: Alexis
What to do when it's out of time for corn vintage?
We, woodworkers are everywhere!!!
papasombre is offline
post #10 of 11 (permalink) Old 04-03-2020, 02:28 AM
neville9999's Avatar
First Name: Neville
Send a message via Yahoo to neville9999
First you eat the corn, then you dry out the cob, very useful then. N
Name:	Toilet paper, yes it will work And it helps relieve that itch too.jpg
mimac, vzbingo and Stick486 like this.
neville9999 is offline
