Recent projects - Router Forums
 21Likes
  • 19 Post By M00sie1945
  • 1 Post By M00sie1945
post #1 of 9 (permalink) Old 04-12-2020, 05:27 PM Thread Starter
First Name: Paul
Default Recent projects
I've been working on developing a different style of cremation urns. What do you think?
Name:	2007-09-01 001 004.jpg
Name:	2007-09-01 001 007.jpg
M00sie1945 is offline
post #2 of 9 (permalink) Old 04-13-2020, 07:57 AM
sreilly's Avatar
First Name: Steve
How are the tops attached? Looks like a very tight fit. How is the inside prepared/finished?
sreilly is offline
post #3 of 9 (permalink) Old 04-13-2020, 09:10 AM Thread Starter
First Name: Paul
Default Urns
The tops are built in place & are not removable. The top rings are assembled with glue, placed in a ring jig to support & keep them round while they are rabbeted on the inside & fitted with a plywood disc top. After sanding both sides flat, the bottom round over is routed & is sanded where it would be difficult to sand after assembling to the main body. After the top is glued & nailed in place, the pre-assembled veneer disc is installed, trimmed with around over bit & all is sanded.
The bottoms are built similarly except instead of a solid plywood disc, a plywood ring ring is used. This creates a recess in the bottom for a removable cover. The inside is sealed with a clear finish.
The way I did it was more a labour of love. A faster way would have to be done before they could be produced commercially, as I had hoped.
MEBCWD likes this.
post #4 of 9 (permalink) Old 04-13-2020, 11:26 AM
First Name: Larry
Looking good Paul
Knot working is offline
post #5 of 9 (permalink) Old 04-13-2020, 11:49 AM
First Name: mary
very nice
marecat3 is offline
post #6 of 9 (permalink) Old 04-13-2020, 11:50 AM
Those are Puuuuurty! I wouldn't feel bad being interned in one of them.
Herb Stoops is online now
post #7 of 9 (permalink) Old 04-14-2020, 06:13 AM
papasombre's Avatar
Country: Venezuela
First Name: Alexis
Hi, Paul.
At a first glance I didn't think that they were urns.
It sounds as a very interesting process to fabricate and attach the rings to the cylinder.
We, woodworkers are everywhere!!!
papasombre is offline
post #8 of 9 (permalink) Old 04-15-2020, 09:27 AM Thread Starter
First Name: Paul
This is a display pedestal I built for a local sculptor using the same 16 sided technique as the urns. The wood is solid quarter sawn white oak with shop sawn veneer of the same wood for the top. The second picture is before the top was covered.
The piece is 24" diameter x 18" high with a 2" recessed base.
https://www.routerforums.com/attachm...385503&thumb=1
https://www.routerforums.com/attachm...385505&thumb=1
Name:	bunch of pictures April 6 2014 024.jpg
Name:	bunch of pictures April 6 2014 013.jpg
marecat3 likes this.
post #9 of 9 (permalink) Old 04-15-2020, 12:04 PM
Bstrom's Avatar
First Name: Brian
Awesome results, awesome wood! Your precision is obvious on this piece.
Common Man Woodworking
Powell, TN
Bstrom is offline
