Pizza Paddle - Page 3 - Router Forums
 36Likes
post #21 of 28 (permalink) Old 05-11-2020, 07:57 PM
RainMan 2.0's Avatar
Excellent outcome Frank
Ok ,I never insulate
RainMan 2.0 is offline
post #22 of 28 (permalink) Old 05-12-2020, 07:24 AM
sreilly's Avatar
First Name: Steve
I was lost without the picture of the jig but no surprise there. I'd certainly submit that to the woodworking magazines. Thanks for posting it.
sreilly is offline
post #23 of 28 (permalink) Old 05-12-2020, 11:37 AM
Originally Posted by Bstrom View Post
Itís a wonder you didnít see that front edge get mangled at such a thin setting - I assume you crept up to your final thickness ever so slowly? I use a sled on my planer to make 1/4Ē panels - will be giving this a try. Very pretty pieced of work you made there....
I could be wrong, but I assume that it is fed so the thin edge comes through the planer last? I think I would use my drum sander,which I use with a sled often, but never tried a taper, I am glad you posted that.
Herb Stoops is online now
post #24 of 28 (permalink) Old 05-13-2020, 06:29 AM Thread Starter
Stoneface's Avatar
First Name: Frank
Herb,
You are correct. Thin edge was first. After planing, I used sled on drum sander to get smooth. This could have been done completely on drum sander, but planer completed job faster. To get thin edge down from 1/8” to about 1/16”, I used a palm sander
Frank
Frank
Stoneface is offline
post #25 of 28 (permalink) Old 05-13-2020, 06:13 PM
Nice job. Ive made a number of them. Every relative has one.
Once you have the taper sled made, it doesn't take that long to make a great present.
Good project to use scraps on.
You can tell a mans planer size, by the size of his peal !
Pirate is offline
post #26 of 28 (permalink) Old 05-13-2020, 06:31 PM
First Name: Aki
Great idea! I would like to try the jig myself. Good looking paddle.
post #27 of 28 (permalink) Old 05-13-2020, 08:31 PM
spes's Avatar
Herb asked if the thin end entered the planer LAST. Your reply was "yes, the thin end enters FIRST".
I'm confused. Which end should enter the planer first?
Great Project.
spes is offline
post #28 of 28 (permalink) Old 05-14-2020, 06:14 AM Thread Starter
Stoneface's Avatar
First Name: Frank
Mike,
Sorry for the confusion. I misread Herb’s question. My reply was correct. I put the thin end in first. I also used very light passes. The handle end has a screw through the hole to keep the paddle from moving on the sled. I also went back to the article to be sure this was the recommended procedure.
Frank
Frank
