WiFi access point installed in corner shelf - Router Forums
 65Likes
post #1 of 31 (permalink) Old 06-04-2020, 08:23 PM Thread Starter
RainMan 2.0's Avatar
Default Installing WiFi access point under corner shelf
Hey guys , I moved my home theatre system around 90 degrees , and in the process of moving speaker outlets I figured I may as well run wire for an Access Point while Iím at it .
The reason for the AP is because my modem is located downstairs in an electronics rack , and although Iím probably only 13í away from it , thereís too many obstructions to get decent signal upstairs, and my iPad keeps defaulting back to 2.4 gig .
I wanted to take the easy route and install an inwall AP . They fit in a conventional outlet , and look athletically pleasing imo , but most members at Ubiquitis forum seem to be against using them ,so I bought another ceiling mount .
Although itís not much bigger than a fire detector, I really didnít want to mount it on my ceiling in the living room , and mounting it on the ceiling in the hallway was an option , but I was still concerned about the thick walls .
So I was looking at the floating corner shelf I had built , my first attempt at one really , and I thought it would be a nice location to mount an AP underneath.
I got the CAT5e ran , and I could have taken the easy route and just mounted the AP underneath, but I thought it would look nicer if it was countersunk 3/8Ē .
So instead of spending 15 minutes Iím spending hours lol .
I used my circle jig and managed to get a hole exactly the diameter of the AP , but had to notch out an area so that I can get access to the hole on the AP that they have to insert a paper clip to remove it from its base .
But that notch will not be very noticeable,as I located it at the rear of the AP .
Iím not finished yet ,as Iím waiting for the glue to dry thatís holding itís base on .
I will add screws ,but needed to get it centred exactly before hand . Tried double sided tape as a temporary way to attach its back plate so that I could install the screws , but I couldnít get it exactly in the middle each time, so thatís where the glue came in .
Will update as I finish. The last pic is where the AP will be located , under the corner shelf with the spider plant on it . Wondering if the wifi will effect the plant ? Maybe it will mutate and attack me in the middle of the night
kp91, jw2170, difalkner and 10 others like this.
Ok ,I never insulate
RainMan 2.0 is offline
post #2 of 31 (permalink) Old 06-04-2020, 08:40 PM
MEBCWD's Avatar
Rick that would have been easy with a CNC and the bottom would be nice and flat. Have you ever thought about buying .... Oh wait ....
That is a great idea and will look nice if someone does see it. Nice job so far.
MEBCWD is online now
post #3 of 31 (permalink) Old 06-04-2020, 08:53 PM Thread Starter
Your too funny , and dead serious I was thinking the same thing lol .
I kept on changing the diameter of the circle jig , and just cut out the adjoining area.
Then I got tired of doing it that way , so I tried to finish it off with the same router free hand , hence the crummy looking cutting in the centre area . But that area thankfully won’t be seen .
I did a nice free hand for the notch I had to add for access to the removal hole in the AP .
But after looking at it and checking it numerous time’s , I still managed to screw up and cut out the wrong side where I needed access for the Ethernet cable .
It will still work though, just pisses me off . Every time I try to free hand stuff I think of Barb and wonder how the heck she does it so well . She’s got quite a talent
MEBCWD likes this.
post #4 of 31 (permalink) Old 06-04-2020, 09:03 PM
First Name: Norm
Very clever idea. Thanks for sharing.
RainMan 2.0 likes this.
NJW63 is offline
post #5 of 31 (permalink) Old 06-04-2020, 09:38 PM
roofner's Avatar
First Name: Gary
Nice work !!!!
roofner is offline
post #6 of 31 (permalink) Old 06-04-2020, 10:01 PM Thread Starter
Well it maybe back the drawing board , but it was expected. For the life of me I cannot get the AP to unlock with a paper clip once itís in place , and itís not even mounted upside down yet lol .
I had a theory before about using magnets to hold it in place, but it seemed like a lot of excessive work .
Iíll head to Canadian Tire tomorrow and see what I can find .
If I cut out the entire circle now , Iíll place a plate over it with magnets and another plate secured to the APs base and have magnets on it also .
I guess the only hassle is going to be buying a forstner bit to fit the magnets circumference
Hereís a pic of that dreaded hole you have to slide something very small into in order to get it to unlock from its base .
I could probably fabricate a special tool , but to hell with it Iíll do a redesign
MEBCWD and Danman1957 like this.
post #7 of 31 (permalink) Old 06-05-2020, 02:01 AM
MEBCWD's Avatar
So what you are telling us now is that is just a prototype so you can work the bugs out before making the actual panel. Magnets sound like a good idea to me and if you use rare earth magnets they probably don't need to be very big.
kp91, MYB and RainMan 2.0 like this.
post #8 of 31 (permalink) Old 06-05-2020, 08:11 AM
sreilly's Avatar
First Name: Steve
We used several of these at the rescue squad and surface mounted them. To be honest we don't even notice them. They are ceiling mounted and blend right in. Just saying.....the modem is in the sever room and there is an AP 30' to the right in the vehicle bay (12 vehicle, 6x2) and then at the other end of the building in the rec hall. We have two networks, the primary private network and the public so law enforcement can park in the lot and log in for access. The range is fantastic and a strong signal throughout. Now if we could get something better then DSL but alas it is the country.
MEBCWD and RainMan 2.0 like this.
sreilly is online now
post #9 of 31 (permalink) Old 06-05-2020, 09:13 AM
roxanne562001's Avatar
First Name: Roxanne
Now that is a Wifi router question/answer in the wood router forums that fits here LOL. That is a cool idea really Looks great Rick.
jw2170, MEBCWD, old55 and 3 others like this.
roxanne562001 is online now
post #10 of 31 (permalink) Old 06-05-2020, 10:02 AM Thread Starter
I’m just being ocd . Although it’s darn near hidden , I thought it would be neat to take it to another level and use my router .
But you are right as they really are not that offensive looking . Do they ever work well though, wow!
Yes I think I’m going against the grain here
I’m going to go shopping , but I suspect I won’t find anything in this one horse town, and I’m not waiting another week for amazon .
I really just want those little guys . Something I can just drill a small hole for and press them in .
But I’m going to head to Staples and see if I can get the next size of paper clip in that dam hole
MEBCWD likes this.
