Mountain scene cutting board, laser engraved - Router Forums
 40Likes
post #1 of 17 (permalink) Old 06-30-2020, 07:19 PM Thread Starter
difalkner's Avatar
First Name: David
Default Mountain scene cutting board, laser engraved
I had a request for a mountain scene cutting board, laser engraved with names and wedding date. I've done a few of these and they come out looking nice but I doubt one ever gets used for anything exception kitchen art!
I drew the original design in CorelDraw where I exported it as an svg to bring into Fusion 360. From there I did the CAD/CAM work to cut the Maple, Walnut, and Cherry. These pieces are about 3/8" thick and the backer board is about 7/8" thick. Everything is glued with TB III and the feet are silicone with SS screws and washers, so everything is FDA approved.
After cutting the mountain scene and gluing it to the backer board it goes to the table saw for trimming to size and then to the router table for rounding the edge. I do the names and date in CorelDraw and take that file to the laser shop for engraving. That way they don't have to do anything except load the file and start the laser machine.
It's finished in mineral oil with Beeswax (our own mix), even though it'll probably just be eye candy for the kitchen.
Sky, mountain, foreground blanks; I picked Walnut with some sapwood to look like snowcapped and some in the foreground -
Mountain scene cutting board, laser engraved-001-mountain-sky-foreground-blanks.jpg
Blanks glued -
Mountain scene cutting board, laser engraved-002-mountain-sky-foreground-blanks-glued.jpg
Blanks glued to backer board -
Mountain scene cutting board, laser engraved-003-mountain-sky-foreground-blanks-glued-back.jpg
Engraving in the laser -
Mountain scene cutting board, laser engraved-004-mountain-sky-laser-engraving.jpg
Finished cutting board -
Mountain scene cutting board, laser engraved-005-mountain-sky-cutting-board.jpg
Mountain scene cutting board, laser engraved-006-mountain-sky-cutting-board.jpg
Enjoy!
David
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is offline
post #2 of 17 (permalink) Old 06-30-2020, 07:42 PM
Wow, did that turn out good, David,I love the color mix forming clouds, prairie,and ocean with surf. The walnut grain gives the illusion of valleys and ridges.
Just spectacular. Thanks for showing the steps of the build.
difalkner likes this.
Herb Stoops is online now
post #3 of 17 (permalink) Old 06-30-2020, 08:57 PM
Nice fit on the different woods!
difalkner and Herb Stoops like this.
HJ
Detroit Burbs
RoutervilleUSA on Etsy
honesttjohn is offline
post #4 of 17 (permalink) Old 06-30-2020, 09:11 PM
impressive..
Stick486 is offline
post #5 of 17 (permalink) Old 06-30-2020, 10:34 PM
JFPNCM's Avatar
First Name: Jon
Very well done. It should remain as eye candy on the wall. Cutting on that would be sinful at best.
Jon
JFPNCM is offline
post #6 of 17 (permalink) Old 07-01-2020, 07:43 AM
First Name: mary
very well done. I love the different woods. I have done a lot of laser engraving on cutting boards but they are all one kind of wood. Some never cut on them but most use the back for cutting and the engraved side as display.
marecat3 is offline
post #7 of 17 (permalink) Old 07-01-2020, 08:08 AM
First Name: Tony
that look's great, love the way you have arranged the grain
Grumpy333sod is offline
post #8 of 17 (permalink) Old 07-01-2020, 08:37 AM
Another unbelievable project, you continue to blow us out of the water.
Thanks for sharing.
Rick
Potowner1 is offline
post #9 of 17 (permalink) Old 07-01-2020, 10:12 AM
First Name: Larry
Excellent work David. I love the different woods.
Knot working is offline
post #10 of 17 (permalink) Old 07-01-2020, 12:08 PM
MEBCWD's Avatar
Great project, really beautiful scene! A good set of pictures showing the process. I foresee people copying this idea.
Most of the inlaid cutting boards will never be used as cutting boards and this one is no exception. It almost makes you want to put a keyhole slot on the back for hanging on the wall instead of feet so it can be set on the counter.
MEBCWD is offline
