Stucco Planter - Router Forums
 43Likes
post #1 of 20 (permalink) Old 08-02-2020, 02:34 PM Thread Starter
First Name: Tony
Default Stucco Planter
well I recently had my house covered in Acrylic rubberized stucco, there was some left over so I attempted to make a stucco planter.
comp56 is offline
post #2 of 20 (permalink) Old 08-02-2020, 09:39 PM
Is that the product that you install styrofoam sheets and then trowel on a layer some kind of material,then spray on the thick rubbized top coat?
JFPNCM likes this.
Herb Stoops is online now
post #3 of 20 (permalink) Old 08-02-2020, 10:17 PM Thread Starter
First Name: Tony
it can be, when they did my house they put a skim coat on of a concrete base because I had already had a concrete base but I had changed all the windows and of course none were original size. then they applied the stucco entirely by trowel. here are some before and after.
comp56 is offline
post #4 of 20 (permalink) Old 08-03-2020, 01:33 AM
That is the regular old cement stucco. The new "Stucco" on commercial building they put 3 1/2" styrofoam on and the trowel on a subbase then spray on a finish coat.
HErb
post #5 of 20 (permalink) Old 08-03-2020, 04:00 AM Thread Starter
First Name: Tony
HErb
this is premixed colour based fine float acrylic stucco and not cementitious stucco which is the old style. it can be applied both ways either spray or by float.
DaninVan, MEBCWD and Herb Stoops like this.
comp56 is offline
post #6 of 20 (permalink) Old 08-03-2020, 11:07 AM
I've never heard of the rubberized stucco. I tried finding it on some of our websites and I came up empty so far. I have a job it would be perfect for.
post #7 of 20 (permalink) Old 08-03-2020, 02:50 PM
mimac's Avatar
First Name: Brian
Chuck it is just acrylic stucco or EIFS. It was invented in Germany after the war as a quick alternative to regular stucco. Dryvit was the first iteration of it I think. It was first used in Canada around 1956. I worked on the first building to use it in Victoria in 1974 an 18 story hi-rise in James Bay. It has certain elastomeric properties and usually goes over a styro-foam sub strata but can go over a well floated cement coat.
mimac is offline
post #8 of 20 (permalink) Old 08-03-2020, 03:49 PM Thread Starter
First Name: Tony
ya maybe rubberized isn't the right word to discribe it but it does have flexing properties versus cracking like the old stuff did.
Herb Stoops likes this.
comp56 is offline
post #9 of 20 (permalink) Old 08-03-2020, 05:56 PM
Can it go directly onto wood Brian? I built part of my house on top of a PWF foundation. I've been trying to think of what I can use to finish the small section between the ground and the bottom of the siding. I was thinking regular stucco but I think the elastomeric would be better.
post #10 of 20 (permalink) Old 08-03-2020, 08:54 PM
mimac's Avatar
First Name: Brian
Yes it can Chuck in a sort of round about way. It is really made for the foam board base which is not like regular styrofoam. It is cooked somehow so that it does not expand and contract with temperature changes. The foam is stuck on with acrylic base coat using a largely notched trowel and reinforced with heavy fiberglass mesh over which the acrylic base coat is spread (sand and acrylic liquid to which you add portland cement). Spreading it takes practice. It is put on tight and as flat as possible as the finish coat goes on very thin and doesn't hide blemishes.
Having said all that I have used it several times over a wood substrata but only for myself and one friend. The first time I used it was over OSB in an unheated storage room interior. I cut wide strips of fibreglass mesh and basically taped the joints and spotted the screw holes just like dry walling. Then I spread the finish coat over top It has to go on tight, think keeping the trowel at a 30-40 degree angle more or less scraping it on. The finish is like spreading thick paint with sand in it. To bed the mesh I just used tile thin set. That finish lasted over 20 years until I converted the room to another use. The next time I did that it was on a friends garden shed over plywood. Basically used the same procedure and it still looks good 12 years later. Last time I did it was for my new garden shed 3 years ago. This was on OSB again using thin set as a base. This time I completely skimmed the shed with base after the taping. I did this myself keeping my eye on the sun and working fast. The finish skins over very quickly. You must keep a wet edge in order to be able to float it. On a stucco job the gut troweling is just about a foot or two in front of the guy floating.
The first picture shows the front with the base skim, the second with the finish all on. I bust it up with Tudor boards to make it manageable for one guy.
mimac is offline
