Funeral urns / boxes - Page 2 - Router Forums
 36Likes
post #11 of 17 (permalink) Old 09-11-2020, 08:53 AM
CharleyL's Avatar
First Name: Charley
When my club, NCWoodworker.com, began making urns for Veterans several years ago, we found out that the National Cemeteries and others would not use them unless the cremation box could be inserted into the urn without the need to open the cremation box. If it had to be opened, the funeral home had to do it before it reached the cemetery. If too large, many other cemeteries would not accept them, since they would not fit into their concrete vaults. We altered our design to accept either of the two standard sized cremation boxes, and now keep quantities of these urns at our National Cemeteries in NC for their use. The bottom is removable, with 5 stainless screws attaching it, the uneven quantity serving to keep the orientation of the bottom correct when being re-installed. The corner joints are usually either box joints or lock miter joints and the top and bottom has rounded or Ogee edges and slightly larger than the box sides. The top is attached via pocket screws from the inside at the time of assembly.
We also provide laser engraved disks 2 3/4" in diameter with the branch of service emblem engraved on it. This emblem gets glued into a 2 3/4 recess in the face side of the urn at the time of it's use. Another laser engraved disk is installed in a similar recess in the bottom of the urn at the time of the urn's construction, that explains who we are and that the urn is being provided "free" and "with thanks for the Veteran's service to our Country".
Our urns are pre-cut from hardwood lumber that is donated by NC sawmills and cut to size by one of our members. These "Kits" are then distributed to other members who assemble and finish them. The Klingspore Workshops has been kind enough to store the finished urns for us in their warehouse, until the time that they are needed by the cemeteries. We also deliver finished urns direct to Veterans, or to their immediate family at their request, if the Veteran will be placed in a family plot in another cemetery.
So, making urns can be a bit more complicated than just making pretty boxes. Our urns are quite plain, but as functional and durable as possible. They get stained in different colors and several coats of polyurethane applied to make them look acceptable at the time of use. Cypress is the wood most preferred for these because of it's long life in wet environments.
Just passing this information along for those considering urn making. We opted for "simple and compatible" to keep them acceptable by all involved here. There are many rules and differences between cemeteries and their ways of dealing with urns. Find out what is required in your area before making them.
Charley
Central North Carolina
CharleyL is offline
post #12 of 17 (permalink) Old 09-11-2020, 03:13 PM
First Name: Steve
What a magnificent job !
ScottyDBQ is offline
post #13 of 17 (permalink) Old 09-11-2020, 04:39 PM
First Name: Tim
Charley
Beautiful! Love what you are doing. I've been looking for a project that I can do for my fellow vets. Can you find some pictures ? Tim
Archi is offline
post #14 of 17 (permalink) Old 09-14-2020, 04:25 AM Thread Starter
kywoodchopper's Avatar
First Name: malcolm
Thanks Charley for the information. I have one of the plastic boxes that funeral homes use to hold the ashes. I make my urns large enough to hold it. I like putting 5-screws in the bottom so the alignment work. I use 4-screws, but have 2-at one end slightly wider apart than the other end so they can see how they go back together. I also use pocket screws to hold the top on because funeral homes don't like any obstruction on the tops. I put a router ogee cut around the top edge of the top and bottom.
Arlington National Cemetery say their urns go in a wall so they can't be over 9" in any direction.
The ones at other funeral home that I have worked with are inserted into a waterproof fiberglass vault. When I started making these I was told if a wooden box goes into the ground without the vault that 20 years later granddaughter would come and ask for her grandmother's ashes because she is moving to California. They said they wouldn't be able to find anything.
I make urn for infants that I donate - generally a couple each year.
Oh, my engraver started calling me Urnie Ashes when he started engraving urns for me. Even his wife calls me Urnie.
Thank you guys for your helping to serve our veterans. I am a Navy veteran.
Malcolm / Kentucky USA
Herb Stoops likes this.
kywoodchopper is offline
post #15 of 17 (permalink) Old 09-14-2020, 07:32 AM
MikeSibley's Avatar
Not trying to change the subject, but when it is my time to go, I told my wife to get a refrigerator box, put me in it and but me on the curb. Then she could announce to everyone that "services were under the direction of Waste Management." I figure it would be much cheaper.
Seriously, guys that's wonderful and generous!
“Those who would give up essential liberty to purchase a little temporary safety, deserve neither liberty nor safety.” – Benjamin Franklin.
MikeSibley is offline
post #16 of 17 (permalink) Old 09-14-2020, 08:43 AM
CharleyL's Avatar
First Name: Charley
@Archi
Tim, I sent you a PM (private message). Please look for it.
Charley
CharleyL is offline
post #17 of 17 (permalink) Old 09-14-2020, 04:23 PM
Nickp's Avatar
First Name: Nick
Malcolm...sorry this is late...love how you split the corners...gives it a real classy look...!
Nick
Nickp is offline
