Garage doors - Router Forums
post #1 of 9 (permalink) Old 06-15-2011, 02:15 PM Thread Starter
First Name: Alan
Default Garage doors
I made a start on my next project today. After returning from the timber merchants with a car full of softwood I cut everything to size and started on the mortices.
Got these done pretty quickly with the morticer and then started on the tennons after cutting a test piece.
This was a quick job too as I used my 'other' RAS with a dado blade in it. When these were finished I used the router to cut a groove in the rails to take the VT&G boards.
While I had the router set up I also routed the rebate for the glass which will fit into the top section.
Then it was time for a dry fit of the frames.
I then installed the diagonal braces and did a glue up and by the end of the day 5.30 ish I also had the boards fitted.
Not a bad day at all. I shall also be building a set of gates to go with these and will be fitting them all together. The gates will probably take a bit longer as there are quite a few mortices on them. We will see.
mailee is offline
post #2 of 9 (permalink) Old 06-16-2011, 01:39 PM Thread Starter
First Name: Alan
I got the garage doors finished today ready for the glass and the hinges.
I won't be fitting them yet as I have a set of gates to build for the same customer so will fit both at the same time.
mailee is offline
post #3 of 9 (permalink) Old 06-16-2011, 10:25 PM
Thanks for posting your work, Alan.
The quality shows, and we can see why you are kept busy.
Give us mere mortals something to aspire to.........
Sydney, Australia
jw2170 is offline
post #4 of 9 (permalink) Old 06-16-2011, 11:12 PM
BigJimAK's Avatar
Looks excellant, Alan..
BigJimAK is offline
post #5 of 9 (permalink) Old 06-17-2011, 10:44 AM
Honored Member
harrysin's Avatar
First Name: Harry
Alan, I think you're cheating by staying up all night, I can't believe that you can do all that in a day.
Harry
harrysin is offline
post #6 of 9 (permalink) Old 06-17-2011, 01:54 PM Thread Starter
First Name: Alan
Ha ha, Harry I know there are not enough hours in the day but I draw the line at working through the night. (Had enough of that when I was employed) I do spend a few hours per night designing, pricing and keeping my books up to date though. I have found that if I do this regularly, like each evening it takes less time and makes things easier. Mind you I did used to spend most evenings in my workshop when was a hobby woodworker.......I just can't seem to get enough of it.
mailee is offline
post #7 of 9 (permalink) Old 12-28-2011, 12:29 AM
First Name: Patrick
good work... was going to go that route myself.. but was curious about the weight.. do you remember?
TomACE is offline
post #8 of 9 (permalink) Old 01-09-2013, 01:24 AM
First Name: Steve
Allan. Just came across your post on your garage doors. Great job. I considered doing the same but thought it was too much work. I still wanted the wood look so I decided to laminate cedar on steel insulated 9' x 9' door. That in it's self was enough wool for me.
Airman is offline
post #9 of 9 (permalink) Old 01-09-2013, 05:49 PM
First Name: Jack
bosox is offline
Garage Door Repair or Plans? pbogi DIY and Renovation 14 12-30-2018 02:27 AM
garage doors - overhead glenndee New Member Introductions 6 09-28-2009 10:46 AM
Garage doors mailee Show N' Tell 5 06-05-2007 10:27 PM
