Vacuum System Almost Finished - Router Forums
post #1 of 6 (permalink) Old 02-08-2012, 11:50 PM Thread Starter
MEBCWD's Avatar
Default Vacuum System Almost Finished
I bought a used expensive vacuum system several years ago and ended up selling it. I used it about 5 1/2 years and got a good profit out of it when I sold it.
I found that I could use another system and started collecting parts as I found them on sale. I finally got all of the parts together for my new vacuum system about 2 weeks ago and have finally started work on the system this week.
The system is designed after the EVS system plans, free from here:
http://www.joewoodworker.com/docs/ProjectEVS.pdf
I had to buy a 10 ft section of 4" PVC pipe so I redesigned the system to have 4 storage reservoirs instead of 2 and they are larger than the plan reservoirs. This gives the system the ability to hold the vacuum level longer and cycle the pump less.
This addition of 2 reservoirs added to the cost of the system for additional parts however, I feel it will be worth it in the overall operation of the system.
The project is not complete at this point however it can now be used!!! I still have to build and install 3 storage drawers. After completing the assembly of the system I ran a hour test.
I ran the system to 25in Hg and unplugged the system for it to sit undisturbed for 1 hour. After 1 hour the system gauge read about 24.25in Hg so I am more than happy with the vacuum retention of the system.
I adjusted the system to turn off at 21in Hg as recommended buy the plans. I checked the cycling and was pleased with the operation of the vacuum controller.
I think this system will work better than the old system I had. I can live with it the way it is until I get the chance to build the storage drawers.
My wife will be babysitting one of the granddaughters for a few days so I am going to do some work in the Kitchen while she is gone and surprise her, so I know I won't be working on anything else for a few days.
Here are some pictures of the vacuum system to this point:
Name:	Main Reservoirs.jpg
Name:	Pump Sub manifold-reservoir.jpg
Name:	Pump - Storage Side.jpg
Name:	Set and ready.jpg
MEBCWD is offline
post #2 of 6 (permalink) Old 02-09-2012, 01:21 AM
Mike, I know it is too late now but in the future I suggest using a white Teflon pipe dope instead of tape. I worked for a company that specialized in Gast and SIHI vacuum pumps. I studied hydraulics; pneumatics controls and circuits and have worked as a pipe fitter building robotic weld systems for most of the last 10 years. Nobody uses tape; tape tends to clog valves as small portions break free inside the systems. That is a headache you don't need and it's easy to avoid.
post #3 of 6 (permalink) Old 02-09-2012, 01:32 AM
BigJimAK's Avatar
Thanks for the heads up, Mike.. I used the tape for the first two-thirds of my air compressor filter / regulator setup, switching to the dope when I had a couple of wire-braid flex hoses made up, at the recommendation of the hydraulic shop.
I have a small leak in my system (60 gal compressor cycles every few hours) and plan to take it apart to rework some day here "soon". I now know to use all dope.
I'd wondered because the dope was kinda messy to use, compared to the tape.
Jim
BigJimAK is offline
post #4 of 6 (permalink) Old 02-09-2012, 02:03 AM Thread Starter
MEBCWD's Avatar
Originally Posted by Mike View Post
Mike, I know it is too late now but in the future I suggest using a white Teflon pipe dope instead of tape. I worked for a company that specialized in Gast and SIHI vacuum pumps. I studied hydraulics; pneumatics controls and circuits and have worked as a pipe fitter building robotic weld systems for most of the last 10 years. Nobody uses tape; tape tends to clog valves as small portions break free inside the systems. Tht is a headache you don't need and it's easy to avoid.
Thanks for the heads up on the tape. Guess I need to pull it all apart and start over from the beginning before I start using it.
The last system I had used a Gast pump and the system had a small leak that I never did find, but it worked good.
Thanks,
Me Mike
MEBCWD is offline
post #5 of 6 (permalink) Old 02-09-2012, 03:16 AM
papawd's Avatar
First Name: warren
Never thought about it like that, guess that is why We use pipe dope on everything at work
papawd is offline
post #6 of 6 (permalink) Old 02-09-2012, 10:17 AM
First Name: Dick
Thanks for the heads up on the tape. I have used the tape in the past for convienance. What you said makes good sence to me "now"
Dick
dick in ia is offline
Shop Made Vacuum hold down SteveMI CNC Routing 3 06-03-2011 09:15 PM
Vacuum Chuck BernieW Woodturning and Lathes 6 02-21-2010 06:21 PM
Outlook Express problems BrianS Lobby 6 01-06-2008 08:23 AM
Vacuum system on/off ..... reible General Routing 5 10-06-2004 12:06 PM
