Segmented Circle Arrowhead Display Stand - Router Forums
post #1 of 17 (permalink) Old 01-10-2014, 10:59 PM Thread Starter
First Name: Dennis
Default Segmented Circle Arrowhead Display Stand
Thanks to Charles/Otis/Richard for their advice on holding compound mitered pieces together for glue-up I just completed a display stand for a friend who has a small arrowhead/pottery collection. Came up with this design so you could remove the pieces easily for closer inspection and yet have a spot for each one for display. The top flat circle went together relatively easy. You can see in pictures 906/07/09 where pairs of the segments were held together with a combination of rubber bands and clamps for glue-up and then these glued pairs were similarly held together for gluing in sets of four. and so on. Pic 911 shows the glued top prior to routing the edge profile and pic 918 shows the completed top. Pic 912 shows the 12 sides of the stand where the display areas were cut out by router or by a drum sander "pushed" into the side using a small metal lathe to drive the drum with the stock being held in a jig. A dry fit was made before glue-up (913) by taping all the pieces together to ensure the fit however I didn't have the nerve to try to glue them all at one time. Pics 914/15/16 show the glue up again using a combination of rubber bands and clamps in the same pair sequence as the top. The last joint did require a little firm nudging however it did ultimately end up with a tight fit. The top of the stand was "leveled" off with a quickie made router sled constructed out of scrap pieces held together with double sided tape. The stand was also held in place on the bench with double sided tape while the top was routed off . This process is shown in pics 919/20/21. The bottom edge of the stand was cut uniform using a cut-off saw to cut each of the 12 sides to uniform length and the bottom edge profile was then routed on the table. Pic 926 shows the stand completed prior to finishing. Pic 944 shows the base to hold the lazy susan which attaches to the stand. I used walnut with yellowheart highlighting and used my favorite walnut stain (French Red ) with a spray on satin varathane finish. The finished stand is shown in pic937 and pic 133 shows the stand with the display items. It was a fun project.
Dennis
routergieck is offline
post #2 of 17 (permalink) Old 01-10-2014, 11:46 PM
Semipro's Avatar
First Name: John_*
That is absolutely gorgeous, great design,love it.
Thank You John
Semipro is online now
post #3 of 17 (permalink) Old 01-11-2014, 12:19 AM
old55's Avatar
First Name: Ross
Really nice work.
Ross,
old55 is offline
post #4 of 17 (permalink) Old 01-11-2014, 02:22 AM
That turned out beautifully Dennis. Now that I'm looking at it I see another very simple clamping solution for future reference. Tape sections together like you did and once you get it all together and with the cone inverted all you have to do is drop two hoops or circles over it. One larger one for near the bottom and a smaller one for the top. Just like in making a barrel. As pointed out before, you don't need a lot of clamping pressure, you just need to hold it together till the glue sets.
post #5 of 17 (permalink) Old 01-11-2014, 06:50 AM
First Name: Steve
Absolutely gorgeous. Great Job. Lots of detail.
belaire445 is offline
post #6 of 17 (permalink) Old 01-11-2014, 07:58 AM
TwoSkies57's Avatar
An exceptionally well executed segmented build!! A segmented build is on my bucket list and this one will be on my reference list. Well done Dennis!!!
Skipper the Penguin
TwoSkies57 is offline
post #7 of 17 (permalink) Old 01-11-2014, 08:06 AM
First Name: Larry
Beautiful Lots of work holding all those segments and getting them to line up. You did a GREAT job. I like the French Red. Never heard of that before.
Knot working is offline
post #8 of 17 (permalink) Old 01-11-2014, 09:17 AM
Iceman567's Avatar
First Name: Ted
Excellent job.
The trouble with quotes on the internet is that you never know if they are genuine. - Abraham Lincoln
Iceman567 is offline
post #9 of 17 (permalink) Old 01-11-2014, 09:57 AM
First Name: Richard
Send a message via Skype™ to rwbaker
Perfect - Baker
rwbaker is offline
post #10 of 17 (permalink) Old 01-11-2014, 10:21 AM
First Name: Bob
Dennis ~ Absolutely stunning. Tell us more about the "French Red" walnut stain. I am not familiar with it.
Bob
Web Shepherd is offline
Forum Suggestion Thread Mark Site Help and Suggestions 131 02-08-2015 10:33 AM
Segmented Circle Glue-up routergieck Jigs and Fixtures 5 12-31-2013 10:18 AM
Arrowhead Display Case JudgeMike General Routing 11 07-09-2012 10:40 PM
Cutting out Circles and Arcs the Easy Way learnexperience Portable Routing 1 11-26-2011 02:29 PM
Bosch 5412L 12" Dual Compound Sliding Miter Saw and T4B Folding Stand Combo CanuckGal Tool Reviews 8 07-24-2009 02:19 PM
