I made a start on my next job today a corner cabinet in pine. Glad to say the customer is going to put a finish on it so it's just a build on this. I started by cutting up two sheets of laminated pine and cutting the angles on them. I then put the slots in for the shelves and the sides with the Domino.
It took a bit of head scratching on how to orient the Domino to get the joints in line?? I had made a rod of the base with all of the angles and joints marked on it to avoid any mistakes. It all worked well and everything fitted together nicely.
I then had to alter the angle of the Domino to join the front edge pieces at 22.5. I used some of the offcuts to make sure they were correct before committing to the cut. I left these in a glue up tonight but shan't get back to this until Friday as I am on another job tomorrow.
