Fill in time project - Router Forums
 17Likes
post #1 of 13 (permalink) Old 01-20-2016, 12:16 AM Thread Starter
Default Fill in time project
This started out to be a quick in between project that took heaps longer than I anticipated.
I saw on you-tube once a golf ball inserted into a piece of wood and thought one day I will give it a go.
My son works in a bearing supplies, so I decided to use a 5/8" steel ball bearing instead of a golf ball.
For my first couple of trials I used pine but I made it too big and also I was not happy with the look.
Next I found an old piece of hardwood house frame with tight grain that machined up just right. With quite some trial and error (slots to small, slots to short, not soft enough) I settled on this size.
First, set it out and drill the holes, must be in the center.
A quick clean up.
After a several failures I found it needed to be boiled for at least 45 minutes not just placed in hot water to have a chance.
Because I have it tight to make the look right my fail rate is high. I get one out of three to go in.
When the hardwood dries out it was still out of shape so I sand it square. This makes the rails slightly thinner which add's to the allusion.
Then after I have finished sanding I apply a coat or two of shellac and we are ready to go.
I carry this in my pocket to show people from time to time, which gets lots of different comments.
By the way I made my son's boss one and he gave me some bearings for free.
Cheers
John T
rjtwin501 is offline
post #2 of 13 (permalink) Old 01-20-2016, 12:24 AM
cool...
rjtwin501 likes this.
post #3 of 13 (permalink) Old 01-20-2016, 12:25 AM
I saw that too. Fun little project. I suspect you could also chill the ball bearing to shrink it up slightly. Making it small and portable was a good idea. However, if you carry it with you all the time, you might get a reputation of being one of those quirky woodworking guys.
Nickp, rjtwin501 and Murtu01 like this.
DesertRatTom is online now
post #4 of 13 (permalink) Old 01-20-2016, 06:15 AM Thread Starter
Tom you are probably right that most people think I am the quirky woodworking guy.
When I go out most of the time I have something I have made with me to show interested people. Most local people in my small community know me from the hardware store I ran for 40 years.
For a long time I carried Larry from the thread here on Router forums "Meet Larry" in a shopping bag ready to get him out and sit on a shop counter. He sure got a lot of response
In Australia we have Men's Sheds when I go to the Men's Shed I take a lot of my silly projects with me, sure stimulates a lot of the men.
Cheers
John T
Speyerer, Gaffboat and Murtu01 like this.
post #5 of 13 (permalink) Old 01-20-2016, 06:43 AM
First Name: Larry
Very Interesting.
Knot working is offline
post #6 of 13 (permalink) Old 01-20-2016, 07:05 AM
Murtu01's Avatar
Country: South Africa
First Name: Rudi
Send a message via Skype™ to Murtu01
Nice project John, in your experience, what would you advise on the difference in slot size to the circumference of the ball or bearing diameter?
The definition of insanity is doing something the same way and expecting a different result. – Albert Einstein
Murtu01 is offline
post #7 of 13 (permalink) Old 01-20-2016, 07:32 AM
mgdesigns's Avatar
First Name: Mark
I've seen similar made with fresh green wood, then bent open, ball inserted, clamped to make straight again, and dried.
Mark Greenbaum
CAD & 3D Designs
Custom Hand Engraving
Maker of Fine Kindling
mgdesigns is offline
post #8 of 13 (permalink) Old 01-20-2016, 10:20 AM
Country: Mexico
First Name: Joseph Anthony
Arrow
+1
RÖENTGEEP is offline
post #9 of 13 (permalink) Old 01-20-2016, 12:39 PM
hawkeye10's Avatar
First Name: Don
I have been meaning to make some of those for a long time. One question I have, did you put any kind of finish on it?
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #10 of 13 (permalink) Old 01-21-2016, 01:16 AM
I wish we had Mens Sheds around here. So many people its hard to connect.
Cherryville Chuck likes this.
My Router Table Project (or, How Much MDF Dust Can I Create?) TeamTurpin Table-mounted Routing 14 12-09-2012 05:11 PM
First Major Project - Custom Closet Cabinets (Phase 1 of 3) riffin-rich Show N' Tell 1 02-05-2012 04:39 PM
Latest Project of 10 boxes GoonMan Show N' Tell 5 05-19-2006 10:29 AM
