Antique Padlock II - Router Forums
 4Likes
  • 4 Post By Herb Stoops
post #1 of 8 (permalink) Old 01-20-2016, 11:22 PM Thread Starter
Default Antique Padlock II
Well here is the second old vintage padlock I found on the internet. I made a replica out of maple, and mahogany. The finish is the same shellac sanding sealer with water base MinWax Poly Acrylic brushed on in thin coats.
Herb Stoops is offline
post #2 of 8 (permalink) Old 01-20-2016, 11:30 PM Thread Starter
The first thing I did was lay up a shackle. This time I started with a layer of maple then a layer of some kind of dark veneer grain going the same way as the maple. Then a layer of 1/4" birch plywood then the thin veneer and the thick maple.They were cold pressed with clamps and let set over night .The next day I trimmed them and cut them out and routed them to size with a 3/4" round over bit.
post #3 of 8 (permalink) Old 01-20-2016, 11:33 PM Thread Starter
Here are some pictures of the internal workings of the lock, pretty basic stuff.
post #4 of 8 (permalink) Old 01-20-2016, 11:37 PM Thread Starter
And here is the finished lock.
Stand by for the next one , it is in the works.
post #5 of 8 (permalink) Old 01-21-2016, 07:35 AM
First Name: Ed
I like these locks and you make it look easy. I will have to try to make one.
herrwood is offline
post #6 of 8 (permalink) Old 01-21-2016, 08:15 AM
RainMan 2.0's Avatar
Another work of art by Herb . You have the master lock craftsman title , that's for sure.
Now your going to have to build a sweet looking display case for all these beautiful locks you built
Ok ,I never insulate
RainMan 2.0 is offline
post #7 of 8 (permalink) Old 01-21-2016, 08:25 AM
so good it hurts Herb...
post #8 of 8 (permalink) Old 01-21-2016, 08:45 AM
First Name: Richard
+1 what Stick said.
Shop guy is offline
Antique lock wooden replica Herb Stoops Show N' Tell 15 01-16-2016 06:13 PM
Antique Brass MaxCohen Starting Off 6 12-05-2011 08:56 AM
