Finished my lazy susan - Router Forums
 51Likes
post #1 of 41 (permalink) Old 02-25-2016, 01:48 PM Thread Starter
First Name: David
Default Finished my lazy susan
Hi again.
I just finished my latest lazy susan and placed it on the dining table. It is the first one where I used a spray application of water based varnish. Several lessons learned.
1. I should have sealed the veneer with shellac first.
2. Water based sand sealer causes the veneer to swell unevenly and thus raise the grain. This required more sanding than otherwise would have been required.
2. The water based finish is perfectly clear but does not look as vibrant as shellac or oil based varnish. Possibly a couple of coats of shellac first would have helped.
3. The water based finish is very hard and takes a 1500 grit wet sanding extremely well. I waited a week after the final coat to fully cure the finish.
4. Buffing could easily produce a piano like finish if I required it.
Oh well there's always ways to improve I just have to make all the mistakes first.
Eastjack is offline
post #2 of 41 (permalink) Old 02-25-2016, 02:55 PM
First Name: Keith
Mistakes? You'e kidding right?
Good grief man, that is way beyond stunning!
Murtu01 and David Dickson like this.
OK, fess up...which one of you clowns stole my sig? It was right here a second ago.
cocobolo1 is offline
post #3 of 41 (permalink) Old 02-25-2016, 03:12 PM
Semipro's Avatar
First Name: John_*
fantastic absolutely beautiful great work
Roy Drake likes this.
Semipro is offline
post #4 of 41 (permalink) Old 02-25-2016, 03:46 PM
First Name: Clay
Excellent work. Any pics of the build that we might see?
fire65 is offline
post #5 of 41 (permalink) Old 02-25-2016, 03:57 PM
Gaffboat's Avatar
First Name: Oliver
That is beautiful!
Gaffboat is offline
post #6 of 41 (permalink) Old 02-25-2016, 04:16 PM
TwoSkies57's Avatar
Now thats my kinda wood-workin!!! Beautiful....
David, have you looked into a random orbital buffer to work your finish schedules?
Does this have a small raised lip around the boarder?
Skipper the Penguin
TwoSkies57 is offline
post #7 of 41 (permalink) Old 02-25-2016, 04:48 PM
First Name: Richard
Wish my mistakes came out looking like that. Man, that is beyond awesome.
Shop guy is offline
post #8 of 41 (permalink) Old 02-25-2016, 05:28 PM
vchiarelli's Avatar
First Name: Vince
Originally Posted by Eastjack View Post
Hi again.
You must have made all your mistakes before you made this lazy susan - it's a work of art.
vchiarelli is offline
post #9 of 41 (permalink) Old 02-25-2016, 06:19 PM
you said it well...
post #10 of 41 (permalink) Old 02-25-2016, 06:21 PM
hawkeye10's Avatar
First Name: Don
There are some great wood workers on this forum and you are one of the top ones. I only wish I could come close to making something like that.
I notice you have been a member for several years with only 10 post. I and I am sure others would like to hear more from you.
Gaffboat, Roy Drake and jj777746 like this.
Don in Murfreesboro,Tn.
hawkeye10 is offline
lazy susan gun rack hilcntry Tools and Woodworking 3 04-13-2015 01:15 PM
I am not lazy susan JFPNCM Lobby 5 03-13-2015 12:11 PM
Any problems cutting Dados in finished wood? JohnnyB60 General Routing 10 08-14-2013 07:02 PM
recess in Lazy Susan macerc Jigs and Fixtures 7 07-04-2012 05:37 AM
Lazy Susan jw2170 Show N' Tell 73 04-14-2011 08:35 AM
