Sign carving sawdust control - Router Forums
 25Likes
post #1 of 20 (permalink) Old 05-04-2016, 06:30 PM Thread Starter
Gaffboat's Avatar
First Name: Oliver
Default Sign carving sawdust control
I was getting tired of sweeping up after routing signs and decided to make a sawdust collector specifically for sign making. I made it out of 1/4" mdf and some 1/2" plywood because I had it on hand. This is a revised version.
My initial attempt had a 2" high opening and it was absolutely worthless. Even sawdust sprinkled in front of it would just drop to the table instead of going in the collector. My shop vac couldn't handle that large an open area.
So, I revised it and made the opening only 3/8" high, added a box on top that serves as a 90º elbow and allows for the hose to be attached. It doesn't catch all the sawdust, but it catches the majority of it. You can see from the "After" photo how little sawdust is on the table after finishing a sign. The low profile is nice and I made the bottom long enough so I can clamp it to the edges of my table.
Name:	1 Collector Before.png
Name:	2 Collector After.png
kp91, BrianS, vindaloo and 17 others like this.
Gaffboat is offline
post #2 of 20 (permalink) Old 05-04-2016, 06:31 PM
nice clean fit and finish too...
post #3 of 20 (permalink) Old 05-04-2016, 07:41 PM
RainMan 2.0's Avatar
Nice job Oliver
Ok ,I never insulate
RainMan 2.0 is online now
post #4 of 20 (permalink) Old 05-04-2016, 07:53 PM
vchiarelli's Avatar
First Name: Vince
Clever idea, Oliver
vchiarelli is offline
post #5 of 20 (permalink) Old 05-04-2016, 08:30 PM
First Name: Richard
Really like that, Oliver. I wonder how something like that would work on a table saw. I may have to try that.
Shop guy is offline
post #6 of 20 (permalink) Old 05-04-2016, 10:14 PM
Nickp's Avatar
First Name: Nick
love your stuff, Oliver...always makes me think how I would use it...
Nick
Nickp is offline
post #7 of 20 (permalink) Old 05-05-2016, 02:53 AM
dalboy's Avatar
First Name: derek
What a great little idea seems to do the job a treat. On the bottom of the opening would it help if it was tapered down to the table to ease the flow
Gaffboat and jj777746 like this.
dalboy is offline
post #8 of 20 (permalink) Old 05-05-2016, 08:30 AM
First Name: Doug
Very creative.....as usual. Thanks for sharing
hilldh is offline
post #9 of 20 (permalink) Old 05-05-2016, 08:36 AM
I was wondering if a guy was to have sanded that bottom edge to a 45 degree angle if it would have made a differance?
post #10 of 20 (permalink) Old 05-05-2016, 11:08 AM Thread Starter
Gaffboat's Avatar
First Name: Oliver
It probably would make a slight difference, Rick, but the bottom is only 1/4" thick and although a little sawdust does build up there, the amount is negligible. The bottom is MDF and I think adding a sharp edge would make it fragile.
Gaffboat is offline
Dirty Little Secrets with Sign Making... newmexico Sign Making 45 06-18-2016 02:59 PM
router sign carving garver New Member Introductions 2 08-05-2013 10:46 PM
For Sale: Sign carving router bit over40pirate Woodworking Classifieds 1 08-06-2009 08:17 PM
Sign material & Sign templates Gunpowder Sign Making 1 09-18-2008 06:30 PM
Sign Making and Carving knotything Sign Making 2 09-16-2008 06:05 PM
