Magic in wood 3 - Router Forums
 4Likes
  • 4 Post By Holic46
post #1 of 5 (permalink) Old 05-07-2016, 12:11 PM Thread Starter
Default Magic in wood 3
Greeting from:
https://www.facebook.com/handcraftedinwood/
Name:	Single 1 candle.jpg
Name:	Single 1 candle2.jpg
Name:	Single 1 candle3.jpg
Name:	Single 1 candle4.jpg
Name:	Round 3 candles.jpg
Name:	Round 3 candles2.jpg
Name:	Wood medium4.jpg
Holic46 is offline
post #2 of 5 (permalink) Old 05-07-2016, 12:22 PM
More beauties! Kindly share your finishing method. If you get the chance, please take a couple of pictures of the process, starting with a raw burl, the cuts, the finishing. I think we'd all enjoy seeing that. Thanks for sharing your work.
post #3 of 5 (permalink) Old 05-07-2016, 12:48 PM Thread Starter
The process is quite simple. Just cut out the required shape (to your imagination), sand down on sander/linisher and apply lacquer. The wood will do the job for you.
It will require several coats and sanding in between coats. That depends on wood - the harder the wood (better quality), better the finish.
You will get better results if you finish individual pieces before assembly and apply a couple last coats on the assembled article, however, make sure not to paint the joints otherwise the glue won't stick.
Holic46 is offline
post #4 of 5 (permalink) Old 05-07-2016, 01:14 PM
that is definitely above my pay grade....
post #5 of 5 (permalink) Old 05-08-2016, 06:47 PM
Special talent you have John. Beautiful work.
billyjim is offline
Aternate to Treated Wood tomp913 Tools and Woodworking 38 12-19-2015 01:25 PM
Wood Species dattashri Wood Species 7 07-26-2012 10:23 AM
Exterior wood Treatment dattashri The Finishing Touch 3 05-14-2012 11:37 AM
Beginner Wood.. New Pupil.. Nef003 Tools and Woodworking 26 03-09-2012 12:10 PM
