Drillpress cabinet - Router Forums
 26Likes
post #1 of 51 (permalink) Old 06-04-2016, 12:03 PM Thread Starter
roofner's Avatar
First Name: Gary
Default Drillpress cabinet
The first picture shows the front view of the cabinet.
The second picture with door open and top shelf slides out to make it easier access contents .
The third picture shows the contents of second shelf.
The fourth picture shows the door construct simple piece of 1/2 inch plywood pocket holed into a 3/4 pine frame.
The fifth picture is fake panel door with molding trim.
The sixth picture shows side panel made same as door everything is attached to 2 x 2 frames that support top and 2 shelf's t nuts are on the inside of frames to hold it together and easier to assemble.
Mike, billyjim, Gaffboat and 7 others like this.
roofner is online now
post #2 of 51 (permalink) Old 06-04-2016, 12:31 PM
Most excellent, Gary!
One thing I noted, and you might want to reconsider:
The casters are fairly close to the vertical axis of the DP. There's a lot of mass up high...ie the centre of gravity.
Moving the wheels to a point as far away from that as possible (outwards) gives you a much more stable base (safety).
Because they're casters, if the DP starts to tip sideways you won't be able to stop it...the wheels will just accelerate the toppling effect.
Mind you, having the cabinet loaded with weight inside it certainly helps bring the C. of G. down, making the assembly more stable....still(?).
Another way to 'kill the cat' might be to rotate the DP 90 deg., and centre it over the length. The only downside to that would be that the cabinet door would be on the side rather than the front. The good news is that you'd have a much wider base and you'd be able to stand closer to the DP table for accurate measuring etc., should you need to.
I know all of the above because my machinist buddy pointed this out to me regarding my mobile base... *oops*
billyjim and Herb Stoops like this.
DaninVan is online now
post #3 of 51 (permalink) Old 06-04-2016, 12:44 PM
I noticed that too. Good job on the cabinet. I have never used pocket holes like that before, learned something today.
on the casters, you could also take a 3/4' thick piece of plywood and cut it so it is a couple of inches wider than your cabinet,but the same width front to back and mount the casters as close to the corners as possible. Then set your cabinet on these, it will greatly increase the stability. Just a suggestion.
DaninVan, jj777746 and hawkeye10 like this.
Herb Stoops is offline
post #4 of 51 (permalink) Old 06-04-2016, 12:52 PM
Nickp's Avatar
First Name: Nick
Yup...wheels are a bit close to center...good thing is you will be using it on the long side...but be careful of putting in long pieces to drill.
...and don't make any sharp turns...
DaninVan, Stick486 and Herb Stoops like this.
Nick
Points to Ponder...
LEARNING - the decision you make to know and
understand more about some thing.
TIME - the thing that gets in the way of learning.
Nickp is online now
post #5 of 51 (permalink) Old 06-04-2016, 01:09 PM
Guest
Nice looking cabinet, Gary. I might copy it...my drill press is still sitting on my Workmate, which effectively removes the Workmate from my tool inventory.
163481 is offline
post #6 of 51 (permalink) Old 06-04-2016, 01:48 PM
RainMan 2.0's Avatar
Great investment Gary . I want to build one myself someday . Would be great having drill bits right there when I need them
Ok ,I never insulate
RainMan 2.0 is offline
post #7 of 51 (permalink) Old 06-04-2016, 02:30 PM
hawkeye10's Avatar
First Name: Don
I agree. That could topple very easy and you would be sick.
Herb Stoops likes this.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #8 of 51 (permalink) Old 06-04-2016, 05:38 PM
Most excellent Gary...
gotta agree on the caster placement..
post #9 of 51 (permalink) Old 06-04-2016, 06:17 PM Thread Starter
roofner's Avatar
First Name: Gary
I agree I built it for space. I got tired of moving around my shop for whatever available flat space it weights 80 or 90 pounds . Didn't use it much to hard to move now moves easy . I want to get a tool box that will fit on top shelf common used tools and drill bits. I will have to work on better wheel setup.
post #10 of 51 (permalink) Old 06-04-2016, 06:27 PM
gusset plate the bottom frame's joints w/ ¾'' ply glued and screwed into place for the casters or plate the enter bottom side to add a boat load of strength to the cabinet...
Drill Press Cabinet from Left-Overs tomp913 Show N' Tell 25 07-27-2015 10:15 AM
The Basic Wall Cabinet MT Stringer Project Plans and How To 15 04-05-2015 05:57 PM
Router Table for Incra LS Positoner completed! Michael H Table-mounted Routing 35 03-19-2015 01:40 PM
Basement cabinet for gun safe DelDave61 New Member Introductions 60 11-26-2014 08:41 PM
Fastening Router Table To Cabinet DONALD Table-mounted Routing 7 04-03-2005 12:04 PM
