Barbie doll shelf for my daughter with my Badog CNC - Router Forums
 10Likes
  • 9 Post By asselin22
  • 1 Post By Shop guy
post #1 of 5 (permalink) Old 06-23-2016, 06:33 AM Thread Starter
asselin22's Avatar
Country: Switzerland
Default Barbie doll shelf for my daughter with my Badog CNC
Iíve been working with badog software for about a year now I was quite convinced that I can make this drawing in less than an hour but in reality it took to many twists and turns and I started to get really creative with my drawings. So it took a little bit longer than expected. you can see below the outline of the pieces and went at as usual on using 3 mm thick plywood with a 1.1 mm diameter tool with 2 teeth.
once all the pieces were cutout of the wood I started to assemble them and had realized that one of the pieces and drawn upside down and if I put it together it would be backwards on the finished model so it was back to the drawing board and I made another piece and erased the original false piece. The entire project took about 15 to 20 minutes to cut if you donít count the time I lost redoing the DXF files in the bundled software I had received with my machine.
hereís an image of the semifinished Barbie doll bookshelf partially assembled before I painted pink. I had to disassemble the entire model in order to get the pieces perfectly covered by the pink
well hereís the finished project all painted of the Barbie bookshelf
asselin22 is offline
post #2 of 5 (permalink) Old 06-23-2016, 07:52 AM
First Name: Richard
I bet that will put a great big smile on your daughter's face. Also will bring you hugs and kisses. Did I mention very nicely done.
asselin22 likes this.
Shop guy is offline
post #3 of 5 (permalink) Old 06-24-2016, 07:04 AM Thread Starter
asselin22's Avatar
thank you
post #4 of 5 (permalink) Old 06-24-2016, 09:31 AM
RainMan 2.0's Avatar
Very cool
Ok ,I never insulate
RainMan 2.0 is online now
post #5 of 5 (permalink) Old 06-24-2016, 11:28 AM
I like it! Really nice work on your part. My little girl is 54, but I remember how things like this made her happy when she was a pre-teen.
DesertRatTom is online now
Creation of doll house with Badog CNC+ free dxf plans for a table asselin22 CNC Routing 0 05-13-2016 09:54 AM
NASA Blue marbel Wooden map done with badog CNC artisan *amazing* asselin22 Show N' Tell 8 05-10-2016 09:45 AM
