Squaring Up Wide Panels - Router Forums
 9Likes
post #1 of 12 (permalink) Old 07-19-2016, 03:49 PM Thread Starter
First Name: Danny
Default Squaring Up Wide Panels
I don't have a panel saw, so usually when I cut up plywood sheets, I have to some times cut it with a straight edge, and a skill saw, and it doesn't end up square. If the panels are small enough, I can square the ends on my crosscut sled. if not this is what I do.
Here is my trick for squaring up wide panels.
I lower my blade then use my crosscut sled to hold one edge square.
then I bring my fence up close to the edge and lock it down, I put a couple three pieces of double sided tape on the panel.
Holding the panel to the crosscut sled and I hold my straight edge against the fence, and hold it in place with the tape.
I remove my sled, and slide the fence back to where I'm taking a small cut on the end of the panel then cut it holding the straight edge up against the fence.
Remove the straight edge, and tape adjust the fence to the correct length and cut the other end of the panel. I now have a square panel.
Panel to big to square up with crosscut sled.
Showing end out of square
Add double sided tape
Attach straight edge.
Set up cut using straight edge against fence.
Now end is square.
Making High Quality Kindling
jd99 is offline
post #2 of 12 (permalink) Old 07-19-2016, 07:07 PM
Interesting solution Danny. Thanks for sharing.
post #3 of 12 (permalink) Old 07-20-2016, 12:19 PM
I cut panels with a 18v circular saw and a straight edge jig. I always measure from a factory edge, and am extremely careful about alignment. I then cut a little oversize so I can finalize the cut on the table saw. Still, I have the occasional "oops" and then I use similar methods to square the piece up. It is usually because I didn't pay close enough attention to aligning the straight edge. I've found it best to mark the cut with a blade rather than even a very sharp pencil. I would rather have a little waste by always using a factory edge than have to mess with squaring things up after.
DesertRatTom is online now
post #4 of 12 (permalink) Old 07-20-2016, 02:44 PM
Garyk's Avatar
First Name: Gary
I use Tom's method but your idea will help on those I still manage to screw up. Thanks.
Garyk is offline
post #5 of 12 (permalink) Old 07-20-2016, 03:02 PM
use the 3/4/5 method off of a good edge and set a straight that way and trim square w/ a CS...
How to Use the 3 4 5 Rule to Build Square Corners: 4 Steps
post #6 of 12 (permalink) Old 07-20-2016, 05:04 PM
RainMan 2.0's Avatar
I was going to build a panel saw before I became aware of track saws . Love mine
RickPr and Rogerdodge like this.
Ok ,I never insulate
RainMan 2.0 is offline
post #7 of 12 (permalink) Old 07-25-2016, 10:10 AM
The sraight edge works well for me, but I have been admiring the track saws. Being able to plunge cut would be nice.
Rogerdodge likes this.
post #8 of 12 (permalink) Old 07-26-2016, 05:10 PM Thread Starter
First Name: Danny
I looked at track saws. I can cut a lot of panels this way, for what I would have to pay for a track saw.
Not every panel I cut is out of square, sometimes the sheet is out of square, and it results in a parallelogram.
jd99 is offline
post #9 of 12 (permalink) Old 07-26-2016, 09:41 PM
Yes I'm aware many are not in a position to buy a track saw . I'm not myself , as I wrote the book on not living within your means lol.
If I had known about making a guide to turn your skill saw into a track saw , I would have done that years ago . I used to use this aluminum guide from crappy tire that didn't work with a darn .
A few members here have made track saws with there skill saws , and from what I seen I believe they would work every bit as good as my track saw .
I'm just glad I never built a panel saw . Always wanted one but I was enlightened by the members here and learned about other alteratives . A panel saw would have also robbed me of much needed room.
I think it's great that Danny has found an option that works for him , and has also shared it with others
post #10 of 12 (permalink) Old 07-26-2016, 10:38 PM
This is the jig I'm talking about. The saw is following the ply's factory straight edge as it cuts through the second piece, usually of 1/4 Masonite. The ply is glued to the masonite. That also gives you a zero clearance edge for less tear out and you know precisely where the cut will be.
This thing really works. I suggest you make it at least 60 inches long. The clamps hold it in place, very important you set them right, if they are offset they will pull the jig to one side.
jw2170 likes this.
Raised Panels: Router vs. Table Saw??? PorterCable690 Jigs and Fixtures 77 03-03-2014 07:34 AM
Glueing panels to Stiles and Rails Kelwing2132 Tools and Woodworking 4 12-23-2011 09:07 AM
Panels: Spaceballs being compressed on assembly? dawziecat Tools and Woodworking 4 02-26-2010 03:28 PM
Squaring plywood panels ShaneB Table-mounted Routing 46 10-14-2009 05:28 PM
Raised Panels Quick and Easy bobj3 Jigs and Fixtures 2 06-03-2006 12:56 PM
