Bubbles in lacquer finish?? - Router Forums
 6Likes
post #1 of 11 (permalink) Old 07-23-2016, 05:13 PM Thread Starter
N'awlins77's Avatar
First Name: Lee
Default Bubbles in lacquer finish??
Anybody have this happen? I was putting my last couple of coats of lacquer finish on my two signs, one I just sold, and one, luckily it was on the back, bubbled like I took a bubble bath next to it. The other one, was on the front, and its the one I've sold. And it has 3 small bubbles, next to each other. But the back of the other one, is covered with bubbles. That one was in the sun, drying and the other one, that only had three small bubbles, was in the shade.
Anyone see this happen before? I never have.
N'awlins77 is offline
post #2 of 11 (permalink) Old 07-23-2016, 06:36 PM
the sun pulled the MC from the wood....
moisture vapor formed the bubbles...
sand it down,,,
let it set in the shade till next day or tw0...
refinish...
keep them outta he sun and use wood w/ a lower MC to start w/...
post #3 of 11 (permalink) Old 07-23-2016, 09:06 PM Thread Starter
N'awlins77's Avatar
First Name: Lee
I can kind of see that Stick, but they both had a couple of coats of the lacquer finish on them. Should that have sealed the moisture in? And this is wood that I have had for some time. I wouldn't have thought it could still have moisture in it. Second, the other sign, that had 3 small bubbles, was in the shade. But I'll spray outside, and then put back in the shed. I was doing it that way before, I don't know why I left if out in the sun. And maybe the other one was just from the heat. Cause I did do the earlier coats, outside (to cut out some of the fumes in there) and then just moved them back in the shed, after they were sprayed. I'm just glad the one I sold, only had three small bubbles in them!!
Thanks Stick!!!
post #4 of 11 (permalink) Old 07-23-2016, 09:47 PM
the wood takes on a higher MC if you have high humidity...
think sponge...
put 10 coats on if you want and that still won't seal in the moisture...
something has to give...
as for heat exposure.. think kiln drying...
spray inside and use a venting ran...
post #5 of 11 (permalink) Old 07-24-2016, 06:30 AM
hawkeye10's Avatar
First Name: Don
Maybe your kids are blowing bubbles.
PS- Sorry this is the best I could do.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #6 of 11 (permalink) Old 07-24-2016, 07:49 AM Thread Starter
N'awlins77's Avatar
First Name: Lee
LOL, I don't think that's it. My Grandchildren are even past blowing bubbles, as my baby Granddaughter starts High School this year!! ;o)
post #7 of 11 (permalink) Old 07-24-2016, 08:40 AM
Wildwood's Avatar
Country: South Africa
First Name: Rob
Is it possible that those are from solvent vapor, from the lower lacquer layer not being fully dry? Just asking.
Wildwood is offline
post #8 of 11 (permalink) Old 07-24-2016, 01:45 PM
anything is possible...
post #9 of 11 (permalink) Old 07-26-2016, 12:03 PM Thread Starter
N'awlins77's Avatar
First Name: Lee
It was at least 3 days, maybe just two days between coats. Which, I would think 2 days should be enough. BUT-- I did find, after sanding the bubbles away, that it did look like the bubbles went below my first coat. Because I sanded it pretty good and I couldn't get all of the rings out. Well, not that I couldn't, but it looked like I was going to have to sand all of the clear coat off, and I wasn't going to do that, for the back of the sign. My other sign, it was in the front, but it was only 3 small bubbles. And after I hand sanded those, and resprayed, you could barely see them. But good news is, they did not bubble again, after spaying them this time, and putting them back in the shop, to dry.
post #10 of 11 (permalink) Old 07-26-2016, 12:22 PM
creative's Avatar
@N'awlins77
I've used propane torches to get epoxy bubbles out. Heat brings air pockets up and out.
Do NOT use a torch near lacquer - it's extremely flammable. But, maybe using a safe source of heat - i.e. some indirect heat from a hair dryer or heat gun while the lacquer is still totally liquid would remove bubbles before they have a chance to slowly blister in the sun.
creative is offline
lacquer finish problem TomK50 The Finishing Touch 11 11-30-2017 09:22 AM
How to do a lacquer finish? DrillingThrough The Finishing Touch 12 08-25-2014 03:54 AM
Finishing the way I see it! by Derek Willis. derek willis Woodworking Articles 0 02-28-2011 09:44 AM
