More on Krylon Cedar spray stain - Router Forums
 29Likes
  • 16 Post By Gaffboat
  • 2 Post By DesertRatTom
  • 2 Post By Herb Stoops
  • 3 Post By Gaffboat
  • 1 Post By Frankj3
  • 3 Post By hawkeye10
  • 1 Post By TenGees
  • 1 Post By BobbyLee
post #1 of 8 (permalink) Old 11-01-2016, 06:51 PM Thread Starter
Gaffboat's Avatar
First Name: Oliver
Default More on Krylon Cedar spray stain
Recently Bobby Lee showed us a sign he had stained with Kylon's spray on Cedar Stain. I finally got a can from Amazon and thought I'd show a side-by-side comparison on a piece of 'white wood' panel sold by Lowe's. As you can see, the transparent stain gives even the cheap wood a nice look with the grain showing through. Just the stain was applied to the top half and no other finish has been added. Thanks again to Bobby Lee for the heads up on where to buy it. I'm looking forward to using it on some future signs.
Name:	Krylon Cedar Stain.jpg
kp91, chessnut2, MEBCWD and 13 others like this.
Gaffboat is offline
post #2 of 8 (permalink) Old 11-01-2016, 07:55 PM
@Gaffboat That is a purty doggone stain. I like a touch of red, and this looks Goldilocks (just right).
Frankj3 and BobbyLee like this.
DesertRatTom is online now
post #3 of 8 (permalink) Old 11-01-2016, 07:59 PM
Oliver is that a spray can , or brush? any fumes?
Herb Stoops is online now
post #4 of 8 (permalink) Old 11-01-2016, 08:03 PM Thread Starter
Gaffboat's Avatar
First Name: Oliver
It's a spray can, Herb and I didn't notice any objectionable fumes.
Frankj3, Herb Stoops and BobbyLee like this.
Gaffboat is offline
post #5 of 8 (permalink) Old 11-02-2016, 12:07 AM
Frankj3's Avatar
First Name: Frank
I bought the same brand, Krylon, but in a Red Wood Stain. I used it on a Red Wood bench I'm repairing and it took nearly 2 days in 90 direct sunlight to dry. It's beautifully stained now.....but took way too long to dry.
Sad part is.....now I have to finish the rest of the picnic table bench I started staining......and I'm not so sure I have that many "hot day" left to dry this thing out when I stain it.
But the Cedar stain seems to be a lot quicker dry compound.
BobbyLee likes this.
Frank
I may not know what I'm doing, but I am having fun doing it wrong!!
Happy Day Veterans!!
Frankj3 is offline
post #6 of 8 (permalink) Old 11-02-2016, 06:27 AM
hawkeye10's Avatar
First Name: Don
It might be the humidity or the paint is old.
MEBCWD, Herb Stoops and BobbyLee like this.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #7 of 8 (permalink) Old 11-02-2016, 10:25 AM
TenGees's Avatar
First Name: Paul
That looks like a colour that I need for a future project where I want to match some pieces. Thanks BobbyLee and Oliver.
TenGees is offline
post #8 of 8 (permalink) Old 11-04-2016, 12:00 PM
BobbyLee's Avatar
First Name: BobbyLee
Your welcome for the heads up Oliver. Side by side comparison looks great. Only thing I could possibly add would be a lighter touch when spraying so that you get the lighter hues instead of a solid color. My test piece looked exactly like your test piece when I first sprayed it. mine looked a little heavy. So when I sprayed the customer's sign I sprayed much lighter and was pleasantly pleased with the results. Not going to let my test piece go to waste though as seen. Will get sanded when done and then lightly sprayed.
Frankj3 likes this.
A piece of wood a day; Helps keep the ill troubles of life away..
BobbyLee is offline
Update: Cedar Stain BobbyLee Sign Making 14 10-21-2016 10:37 PM
Krylon Snap and Spray Can Handle MT Stringer Tool Reviews 11 10-12-2016 11:06 PM
Cedar shim stain chessnut2 The Finishing Touch 3 05-06-2014 11:44 AM
wipe on stain clear coat more stain (layers) tiggol The Finishing Touch 6 03-22-2010 10:35 AM
