Scrap pieces - Router Forums
 56Likes
post #1 of 14 (permalink) Old 11-02-2016, 08:58 AM Thread Starter
Default Scrap pieces
Got a bunch of baltic birch cutoffs from a project my buddy did - - started off making a few of these.
HJ
kp91, JFPNCM, chessnut2 and 11 others like this.
honesttjohn is offline
post #2 of 14 (permalink) Old 11-02-2016, 09:52 AM
My wife didn't notice the one about washing dishes.
MEBCWD, TenGees, Frankj3 and 2 others like this.
post #3 of 14 (permalink) Old 11-02-2016, 09:57 AM
Just a quick thought. If you trim the back of the sign at an angle (1/4 thick on top, 3/4 on the bottom) you'd have a little, free standing sign. Start that angled cut about 3/4 up from the base and rout a bead around the bottom to give it a little dress-up. That would make little signs like this into nifty little gifts. I'm a business consultant...always thinking marketing, can't help myself LOL.
JFPNCM, Gaffboat, Frankj3 and 2 others like this.
post #4 of 14 (permalink) Old 11-02-2016, 10:21 AM Thread Starter
Trying to grasp what you said, Tom. Got an example? The small ones are 9 x 7.
HJ
MEBCWD, Frankj3 and BobbyLee like this.
post #5 of 14 (permalink) Old 11-02-2016, 10:46 AM
MEBCWD's Avatar
Good use of the scrap material.
Frankj3, honesttjohn and BobbyLee like this.
MEBCWD is offline
post #6 of 14 (permalink) Old 11-02-2016, 11:30 AM
Here is a profile. I also suggest rounding over the top. Now, if you really like this idea, cut first, then put the lettering on the slanted surface. These would also make good awards. To cut the lettering on the slanted surface, you'd need a jig, cut to the angle of the slant to support it underneath so the CNC or router had a horizontal surface to work on.
Here are a couple of profiles, vertical for the suggested angle cut and bead, the horizontal to suggest how to support the back so the surface is horizontal for doing the lettering. The gray block could be much wider and longer than needed for these little guys so you can do larger signs. Double sided tape or sandpaper on the surface of the gray support block will hold the workpiece firmly in place.
Name:	sign profile.jpg
kp91, TenGees, Frankj3 and 2 others like this.
post #7 of 14 (permalink) Old 11-02-2016, 11:38 AM
Proving once again that there is no such thing as scrap, only wood that hasn't found its final purpose yet. I like the themes John.
post #8 of 14 (permalink) Old 11-03-2016, 08:12 AM
hawkeye10's Avatar
First Name: Don
Great work John and I believe like you there is no such thing as scrap wood.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #9 of 14 (permalink) Old 11-03-2016, 08:54 AM
First Name: lee
I used a Baltic birch scrap for my table saw fence. It was a much more consistent diameter than the pine I was using. When I put my gauge on it in squaring to the miter slot on the table saw I was within .005 off across the whole table saw fence which I think is very good. That Baltic birch is good stuff. There are lots of uses for it. I do like your signs. Keep up the good work.
coxhaus is offline
post #10 of 14 (permalink) Old 11-03-2016, 12:28 PM
First Name: Richard
Like the little signs, John.
Shop guy is offline
Scrap Lumber - Repurposed! MT Stringer Show N' Tell 26 11-13-2015 02:30 PM
Tip for sanding very small pieces Gaffboat Tools and Woodworking 10 11-04-2014 04:26 AM
Making Perfectly Squared Pieces Careysub Table-mounted Routing 28 07-15-2011 06:22 PM
How to cut slots in 2 pieces that are not straight on outsides. Midnight Shadow General Routing 4 07-26-2010 11:04 AM
Cut both box joint pieces at once? Fretts Jigs and Fixtures 2 06-15-2010 01:17 PM
