Have I mentioned I Hate Carving Pine - Router Forums
 26Likes
post #1 of 15 (permalink) Old 12-11-2016, 10:37 PM Thread Starter
Frankj3's Avatar
First Name: Frank
Default Have I mentioned I Hate Carving Pine
I hate......let me say this again.....I HATE carving and painting Pine!!
I've done the sanding sealer before carving trick.....not good.
I've done the clear acrylic application before painting trick.....not good.
I've done several light coats of paint trick.....not good.
I've done the heavy coat of paint trick.....not good.
Get the feelings that I have? Pine is not good to, or for me.
Any suggestions because I am at wits end.
Thanks!
chessnut2 and BobbyLee like this.
Frank
I may not know what I'm doing, but I am having fun doing it wrong!!
Happy Day Veterans!!
Frankj3 is offline
post #2 of 15 (permalink) Old 12-11-2016, 11:05 PM
kp91's Avatar
First Name: Doug
Poplar will do that as well, especially if it is a 12" x 40" x 1.5" slab you had to glue up for a project... I fully understand your frustration
Frankj3, BobbyLee and Trujeepr like this.
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #3 of 15 (permalink) Old 12-12-2016, 02:23 AM
JOAT's Avatar
First Name: Theo
What kind of paint are you using? That could make a difference.
I've not painted many carved items, but have done a few. Used acrylic latex, and had no issues at all.
Frankj3 and BobbyLee like this.
JOAT is online now
post #4 of 15 (permalink) Old 12-12-2016, 06:47 AM Thread Starter
Frankj3's Avatar
First Name: Frank
Theo, I am using Rustoleum 2X Black Primer. I don't have this issue on other species of wood. Only in Pine.
Thanks.
BobbyLee likes this.
Frank
Frankj3 is offline
post #5 of 15 (permalink) Old 12-12-2016, 10:59 AM
First Name: Roy
Take the sign outside. Get a two pound hammer. Beat it to pulp! It obviously won't make the sign any good, but you'll feel much, much better. Have a good/better day.
Frankj3, honesttjohn and BobbyLee like this.
Roy Drake is offline
post #6 of 15 (permalink) Old 12-12-2016, 11:45 AM
MEBCWD's Avatar
Frank I use Marsh Spray Stencil ink when I do v-carving on my CNC machine (I also use masking). It dries fast so if you don't spry too much at a time it works. On select pine I usually spray several light coats from different angles (don't try to do it all at once, keep it dry) spray and let it dry between coats. This might take quite a few coats to cover it all but it keeps it from bleeding. On hard woods like Cherry and Oak I spray from 4 different directions at one time and then let it dry. I have had it bleed when I get in a hurry and put heavy coats on it get it covered, then I have the headache of cleanup or re-cutting the project, not fun and wastes time and materials.
MEBCWD is offline
post #7 of 15 (permalink) Old 12-12-2016, 02:49 PM
I like Doug's suggestion. Popular is light, soft, usually cheaper, and lacks the pitch that pine is famous for.
post #8 of 15 (permalink) Old 12-12-2016, 05:01 PM
Marco's Avatar
Thanks!
Not trying to be a smart#$#%# Frank but STOP USING PINE!
Hutzul, Frankj3, hawkeye10 and 1 others like this.
[B“It’s not a mistake, it’s a design feature”][/B]
Marco is offline
post #9 of 15 (permalink) Old 12-12-2016, 06:27 PM Thread Starter
Frankj3's Avatar
First Name: Frank
Thanks for the pointers......especially yours Roy! LOL
MEBCWD and BobbyLee like this.
Frank
Frankj3 is offline
post #10 of 15 (permalink) Old 12-25-2016, 11:13 PM
BobbyLee's Avatar
First Name: BobbyLee
Late getting to this Frank. But are you sanding before sealing it? You've seen the Tack sign & Provenzano sign both in pine with no bleeding. I sanded real good first then sealed before painting.
kp91, MEBCWD and Frankj3 like this.
A piece of wood a day; Helps keep the ill troubles of life away..
BobbyLee is offline
Pine for flooring? T- stew DIY and Renovation 10 04-07-2015 12:14 AM
New to wood working and to this forum. jaithran New Member Introductions 9 11-25-2014 12:50 AM
CNC Is Not For Us... Prefer Hand Carving newmexico Sign Making 0 03-23-2012 06:08 AM
My First Cowboy Carving.... challagan Pyrography and Carving 29 04-24-2009 10:54 PM
Pine Settle nzgeordie Show N' Tell 10 02-11-2008 09:05 AM
