Problem with painted letters - Page 2 - Router Forums
 11Likes
post #11 of 13 (permalink) Old 02-12-2018, 09:22 AM
First Name: mary
welcome aboard
nice sign
marecat3 is offline
post #12 of 13 (permalink) Old 02-12-2018, 09:50 AM
The Hobbyist's Avatar
First Name: Joe
I use flat paint to color the letters. I am guessing that Rustoleum enamel does not allow air and gasses to pass through it, which would of course create a "balloon" that the gases could inflate. If you want to coat the whole thing in a thick plastic coating, you should allow time for it to breathe. I would not coat it right away after cutting the wood.
Joe
http://www.aguyintown.com
Retirement is overrated.
The Hobbyist is offline
post #13 of 13 (permalink) Old 02-12-2018, 01:28 PM Thread Starter
DaninVan: I bought a inexpensive 5amp handheld Rigid at HD and used a 1/8" straight cut bit for one sign and then bought a little nicer Amana tapered bit (Amana Tool 45776 Solid Carbide 30 Degree Engraving 0.060 Tip Width x 1/4 SHK x 2-1/4 Inch Long Signmaking Router Bit) for the second sign.
DaninVan likes this.
Chiselhead is offline
Sanding Letters After Cutting Karluv Table-mounted Routing 17 09-10-2019 07:32 PM
2" wide letters for bar top ponch37300 Sign Making 13 04-05-2015 03:01 PM
Introduction of myself and my problem. samfromhernando New Member Introductions 26 10-06-2014 10:08 PM
cutting letters tjw Sign Making 6 09-21-2010 02:51 PM
cutting letters tjw New Member Introductions 4 09-17-2010 07:50 AM
